[mpich-discuss] installing and using	MPI_PUBLISH_NAME	andMPI_LOOKUP_NAME with mpich2
    Bernard Secher - SFME/LGLS
    bernard.secher at cea.fr
    Thu Jun 16 09:21:57 CDT 2011
OK Dave, so why I get these error messages with hydraserver ?
bERNARD
Dave Goodell a écrit :
> Be aware that Leon's advise is exactly the opposite of what we (the MPICH2 developers) would recommend.  The mpd process manager is deprecated and we really don't support it anymore.
> -Dave
> On Jun 16, 2011, at 7:40 AM CDT, Bernard Secher - SFME/LGLS wrote:
>> My test program work very well with opnempi, but I want to use mpich2 too, if it is possible...
>> How can I use mpd  with mpich2 ?
>> Leon Yuhanov a écrit :
>>> hey,ditch hydra. use mpd its easier for quick simple stuff. move onto lam-mpi or open-mpi after that.
>>> <bernard.secher at cea.fr>
>>>  wrote:
>>> When I tried to use hydra_nameserver I get the followinf error message
>>> when I launch my application:
>>> [secher at is209011 essai]$ [mpiexec at is209011] HYDU_sock_read
>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/utils/sock/sock.c:223):
>>> read errno (Input/output error)
>>> [mpiexec at is209011] control_cb
>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/pm/pmiserv/pmiserv_cb.c:249):
>>> assert (!closed) failed
>>> [mpiexec at is209011] HYDT_dmxu_poll_wait_for_event
>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/tools/demux/demux_poll.c:77):
>>> callback returned error status
>>> [mpiexec at is209011] HYD_pmci_wait_for_completion
>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/pm/pmiserv/pmiserv_pmci.c:206):
>>> error waiting for event
>>> [mpiexec at is209011] main
>>> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/ui/mpich/mpiexec.c:404):
>>> process manager error waiting for completion
>>> What is wrong
>>> My application is just a little test program. I have attached it to this
>>> message.
>>> Bernard
>>> Pavan Balaji a écrit :
>>>> [please keep mpich-discuss cc'ed]
>>>> On 06/16/2011 02:18 AM, Bernard Secher - SFME/LGLS wrote:
>>>>> How can I use the default publish mechanism? My Publish/lookup is
>>>>> hapenning between two different applications. Is there an option to give
>>>>> to mpiexec for that ?
>>>> Do you have a shared file-system? If yes, you don't need to modify
>>>> anything. It should just work. If no, then read below:
>>>>> If I use the pmi option, the mpiexec -nameserver -help give the
>>>>> following message:
>>>>> -nameserver: Nameserver to use for publish/lookup (format is host:port)
>>>>> I don't understand what I have to do with this option.
>>>>> First I launch the hydra_nameserver . Do I give some options to
>>>>> hydra_nameserver ? Do I give some options then, to the two mpiexec to
>>>>> launch my two applications?
>>>> There are no options required for hydra_nameserver. The two mpiexec's
>>>> will need the -nameserver {hostname} option, where {hostname} is the
>>>> name of the host where the nameserver is running.
>>>>  -- Pavan
>>        _\\|//_
>>       (' 0 0 ')
>> ____ooO  (_) Ooo______________________________________________________
>>  Bernard Sécher  DEN/DM2S/SFME/LGLS    mailto :
>> bsecher at cea.fr
>>  CEA Saclay, Bât 454, Pièce 114        Phone  : 33 (0)1 69 08 73 78
>>  91191 Gif-sur-Yvette Cedex, France    Fax    : 33 (0)1 69 08 10 87
>> ------------Oooo---------------------------------------------------
>>        oooO (   )
>>         \ ( (_/
>>          \_)
>> Ce message électronique et tous les fichiers attachés qu'il contient
>> sont confidentiels et destinés exclusivement à l'usage de la personne
>> à laquelle ils sont adressés. Si vous avez reçu ce message par erreur,
>> merci d'en avertir immédiatement son émetteur et de ne pas en conserver
>> de copie.
>> This e-mail and any files transmitted with it are confidential and
>> intended solely for the use of the individual to whom they are addressed.
>> If you have received this e-mail in error please inform the sender
>> immediately, without keeping any copy thereof.
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
       _\\|//_
      (' 0 0 ')
 Bernard Sécher  DEN/DM2S/SFME/LGLS    mailto : bsecher at cea.fr
       oooO (   )
        \ ( (_/
         \_)
de copie.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110616/a2269918/attachment.htm>
