[mpich-discuss] installing and using MPI_PUBLISH_NAME and MPI_LOOKUP_NAME with mpich2
Pavan Balaji balaji at mcs.anl.gov
Wed Jun 15 08:48:32 CDT 2011
The default publish mechanism is to use the file-system assuming there's
a shared file system. Does that not work for you?
Alternatively, you can use --with-name-publisher=pmi. In this case there
are two possibilities:
1. If your publish/lookup is happening within the same application
(launched using one mpiexec), then there's nothing you need to do. Just
launch the application normally, and it'll function correctly.
2. If your publish/lookup is happening between two different
applications (launched using more than one mpiexec), then you'll need to
launch a separate nameserver (./mpich2-install/bin/hydra_nameserver) and
get each mpiexec to connect to this common nameserver by passing the
-nameserver option to mpiexec. mpiexec -nameserver -help will give you
more information.
  -- Pavan
On 06/15/2011 06:49 AM, Bernard Secher - SFME/LGLS wrote:
> Hello list,
> I want to install and use MPI_PUBLISH_NAME and MPI_LOOKUP_NAME with mpich2.
> I saw there is a --with-namepublisher=name configure option
> with name =     no (no service available)
>                           mpd
>                           file:directory (optional directory)
>                           pmi
> What are the differences between the different options ?
> I tried to use mpd option but I got the following error message:
> "configure: error: The mpd nameserver requires the mpd process manager"
> Please, can anybody help me about this ?
> Bernard
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
