[mpich-discuss] Problem with tcsh and ppn >= 5
    Anthony Chan
    chan at mcs.anl.gov
    Tue Jun 14 15:22:15 CDT 2011
Well, on F14 where csh/tcsh works with hydra, the csh/tcsh are also
6.17.00.  But then Redhat may have patched it.
/home/chan/mpich_work> cat /etc/issue
Fedora release 14 (Laughlin)
/home/chan/mpich_work> install/bin/mpiexec -n 1 /bin/csh -c build/examples/cpi
Process 0 of 1 is on localhost.localdomain
pi is approximately 3.1415926544231341, Error is 0.0000000008333410
wall clock time = 0.000807
/home/chan/mpich_work> csh --version
tcsh 6.17.00 (Astron) 2009-07-10 (x86_64-unknown-linux) options wide,nls,dl,al,kan,rh,color,filec
FYI: the system that has buggy tcsh/csh runs Ubuntu 10.04.2 LTS.
A.Chan
----- Original Message -----
> Thanks, that looks like the same error we are seeing. Our 2 core
> system has 6.13.00 and it works fine. Our 8 core systems have 6.14.00
> and don't work. What version do you have on the system that works? I
> will try using 6.13.00 on our 8 core systems.
> > -----Original Message-----
> > From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-
> > bounces at mcs.anl.gov] On Behalf Of Anthony Chan
> > Sent: Tuesday, June 14, 2011 1:08 PM
> > To: mpich-discuss at mcs.anl.gov
> > Subject: Re: [mpich-discuss] Problem with tcsh and ppn >= 5
> > What version of csh that you are using. Pavan told me once that
> > there are
> > some versions of buggy csh/tcsh that prevents hydra from working
> > correctly.
> > But on my F14 system, everything works fine with tcsh/csh. On the
> > system
> > with buggy csh/tcsh, I got the following.
> > A.Chan
> > /homes/chan> csh --version
> > wide,nls,dl,al,kan,rh,nd,color,filec
> > /homes/chan> tcsh --version
> > /homes/chan> /disk/chan/mpich2_work/install/bin/mpiexec -n 1 -ppn 5
> > /bin/csh -c /disk/chan/mpich2_work/build/examples/cpi
> > [cli_0]: write_line error; fd=6 buf=:cmd=init pmi_version=1
> > pmi_subversion=1
> > system msg for write_line failure : Bad file descriptor
> > [cli_0]: Unable to write to PMI_fd
> > [cli_0]: write_line error; fd=6 buf=:cmd=get_appnum
> > system msg for write_line failure : Bad file descriptor Fatal error
> > in MPI_Init:
> > Other MPI error, error stack:
> > MPIR_Init_thread(388):
> > MPID_Init(107).......: channel initialization failed
> > MPID_Init(389).......: PMI_Get_appnum returned -1 /homes/chan>
> > /disk/chan/mpich2_work/install/bin/mpiexec -n 1 -ppn 5 /bin/tcsh -c
> > pmi_subversion=1
> > in MPI_Init:
> > > > bounces at mcs.anl.gov] On Behalf Of Frank Riley
> > > > Sent: Tuesday, June 14, 2011 12:20 PM
> > > > Subject: [mpich-discuss] Problem with tcsh and ppn >= 5
> > > > Hello,
> > > > We are having a problem running more than 4 processes per node
> > > > when
> > > > using the tcsh shell. Has anyone seen this? Here is a simple
> > > > test
> > > > case:
> > > > mpiexec -n 1 -ppn 5 /bin/csh -c /path/to/a.out
> > > > where a.out is a simple C test executable that does a MPI_Init
> > > > and a
> > > > MPI_Finalize. The error is as follows:
> > > > [cli_3]: write_line error; fd=18 buf=:cmd=init pmi_version=1
> > > > pmi_subversion=1 system message for write_line failure : Bad
> > > > file
> > > > descriptor
> > > > Note that the following command (bash shell) works fine:
> > > > mpiexec -n 1 -ppn 5 /bin/sh -c /path/to/a.out
> > > > Our mpich2 is version 1.3.2p1 and is built with the following
> > > > flags:
> > > > --enable-fast --enable-romio --enable-debuginfo --enable-smpcoll
> > > > --enable-
> > > > mpe --enable-threads=runtime --enable-shared --with-mpe
> > > I forgot to mention that we do not see the failure on our cluster
> > > that
> > > has nodes with 2 cores each. It only fails on our clusters that
> > > have
> > > nodes with 8 cores each.
> > > _______________________________________________
> > > mpich-discuss mailing list
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
