[mpich-discuss] Problem with tcsh and ppn >= 5
    Frank Riley
    fhr at rincon.com
    Tue Jun 14 15:11:45 CDT 2011
Thanks, that looks like the same error we are seeing. Our 2 core system has 6.13.00 and it works fine. Our 8 core systems have 6.14.00 and don't work. What version do you have on the system that works? I will try using 6.13.00 on our 8 core systems.
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-
> bounces at mcs.anl.gov] On Behalf Of Anthony Chan
> Sent: Tuesday, June 14, 2011 1:08 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Problem with tcsh and ppn >= 5
> What version of csh that you are using. Pavan told me once that there are
> some versions of buggy csh/tcsh that prevents hydra from working correctly.
> But on my F14 system, everything works fine with tcsh/csh.  On the system
> with buggy csh/tcsh, I got the following.
> A.Chan
> /homes/chan> csh --version
> tcsh 6.17.00 (Astron) 2009-07-10 (x86_64-unknown-linux) options
> wide,nls,dl,al,kan,rh,nd,color,filec
> /homes/chan> tcsh --version
> /homes/chan> /disk/chan/mpich2_work/install/bin/mpiexec -n 1 -ppn 5
> /bin/csh -c /disk/chan/mpich2_work/build/examples/cpi
> [cli_0]: write_line error; fd=6 buf=:cmd=init pmi_version=1
> pmi_subversion=1
> system msg for write_line failure : Bad file descriptor
> [cli_0]: Unable to write to PMI_fd
> [cli_0]: write_line error; fd=6 buf=:cmd=get_appnum
> system msg for write_line failure : Bad file descriptor Fatal error in MPI_Init:
> Other MPI error, error stack:
> MPIR_Init_thread(388):
> MPID_Init(107).......: channel initialization failed
> MPID_Init(389).......: PMI_Get_appnum returned -1 /homes/chan>
> /disk/chan/mpich2_work/install/bin/mpiexec -n 1 -ppn 5 /bin/tcsh -c
> pmi_subversion=1
> > > bounces at mcs.anl.gov] On Behalf Of Frank Riley
> > > Sent: Tuesday, June 14, 2011 12:20 PM
> > > Subject: [mpich-discuss] Problem with tcsh and ppn >= 5
> > > Hello,
> > > We are having a problem running more than 4 processes per node when
> > > using the tcsh shell. Has anyone seen this? Here is a simple test
> > > case:
> > > mpiexec -n 1 -ppn 5 /bin/csh -c /path/to/a.out
> > > where a.out is a simple C test executable that does a MPI_Init and a
> > > MPI_Finalize. The error is as follows:
> > > [cli_3]: write_line error; fd=18 buf=:cmd=init pmi_version=1
> > > pmi_subversion=1 system message for write_line failure : Bad file
> > > descriptor
> > > Note that the following command (bash shell) works fine:
> > > mpiexec -n 1 -ppn 5 /bin/sh -c /path/to/a.out
> > > Our mpich2 is version 1.3.2p1 and is built with the following flags:
> > > --enable-fast --enable-romio --enable-debuginfo --enable-smpcoll
> > > --enable-
> > > mpe --enable-threads=runtime --enable-shared --with-mpe
> > I forgot to mention that we do not see the failure on our cluster that
> > has nodes with 2 cores each. It only fails on our clusters that have
> > nodes with 8 cores each.
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
