[mpich-discuss] NO_Port Error
    Cristina Montañola
    cristina.montanola at bsc.es
    Wed Jun  1 06:17:26 CDT 2011
> Can you upgrade to natty? It uses a newer version of MPICH2, which
> doesn't use MPD anymore.
>  -- Pavan
I would prefer not to do so, I always get in trouble when upgrading...
But if I can't find any solution, I might try that.
Thanks for the advice,
Cristina
WARNING / LEGAL TEXT: This message is intended only for the use of the
individual or entity to which it is addressed and may contain
information which is privileged, confidential, proprietary, or exempt
from disclosure under applicable law. If you are not the intended
recipient or the person responsible for delivering the message to the
intended recipient, you are strictly prohibited from disclosing,
distributing, copying, or in any way using this message. If you have
received this communication in error, please notify the sender and
destroy and delete any copies you may have received.
http://www.bsc.es/disclaimer.htm
