[mpich-discuss] NO_Port Error
    Cristina Montañola
    cristina.montanola at bsc.es
    Wed Jun  1 05:53:16 CDT 2011
Hi!
On 01/06/11 02:50, Shawn Kim wrote:
> Did you set up the password in the file ".mpd.conf"?
> For example,
> vi .mpd.conf
> MPD_SECRETWORD=xxxx (whatever you want)
Yes, it's done.
> Also, did you set up the ssh that can access to the other processes
> (clients) without password?
I'm only using one process, so I don't use ssh. Anyway, ssh is installed.
> - Shawn
Cristina
WARNING / LEGAL TEXT: This message is intended only for the use of the
individual or entity to which it is addressed and may contain
information which is privileged, confidential, proprietary, or exempt
from disclosure under applicable law. If you are not the intended
recipient or the person responsible for delivering the message to the
intended recipient, you are strictly prohibited from disclosing,
distributing, copying, or in any way using this message. If you have
received this communication in error, please notify the sender and
destroy and delete any copies you may have received.
http://www.bsc.es/disclaimer.htm
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110601/79b900b3/attachment.htm>
