[mpich-discuss] DataType Problem
James Dinan
dinan at mcs.anl.gov
Mon Jan 31 11:13:07 CST 2011
Hi Michele,
Another quick comment:
Don't forget to free your MPI datatypes when you're finished with them.
This shouldn't cause the error you're seeing, but it can be a resource
leak that builds up over time if you call this routine frequently.
call mpi_type_free(temp, errorMPI)
call mpi_type_free(temp2, errorMPI)
call mpi_type_free(temp3, errorMPI)
Best,
~Jim.
On 01/31/2011 11:07 AM, James Dinan wrote:
> Hi Michele,
> I'm looking this over and trying to put together a test case from the
> code you sent. One thing that looks questionable is the type for 'ext'.
> The call to mpi_type_size wants an integer, however the
> mpi_type_create_resized calls want an integer of kind=MPI_ADDRESS_KIND.
> Could you try adding something like this:
> integer :: dcsize
> integer (kind=MPI_ADDRESS_KIND) :: ext
> call mpi_type_size( mpi_double_complex , dcsize , errorMPI)
> ext = dcsize
> Thanks,
> ~Jim.
> On 01/30/2011 02:15 AM, Michele Rosso wrote:
>> Hi,
>> I am developing a subroutine to handle the communication inside a group
>> of processors.
>> The source code is attached.
>> Such subroutine is contained in a module and accesses many of the data
>> it needs and the header "mpi.h" from another module (pmu_var).
>> As an input I have a 3D array (work1) which is allocated in the main
>> program. As an output I have another 3D matrix (work2) which is
>> allocated in the main program too. Both of them are of type complex and
>> have intent INOUT (I wanna use the subroutine in a reversible way ).
>> Since the data I wanna send are not contiguous, I defined several data
>> types. Then I tested all of them with a simple send-receive
>> communication in the group "mpi_comm_world".
>> The problem arises when I tested the data type "temp3": the esecution of
>> the program stops and I receive the error:
>> rank 0 in job 8 enterprise_45569 caused collective abort of all ranks
>> exit status of rank 0: killed by signal 9
>> Notice that work1 and work2 have different size but the same shape and
>> the data type should be coherent with them.
>> Has anyone and idea of which the problem could be?
>> Thanks in advance,
>> Michele
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
