[mpich-discuss] DataType Problem
James Dinan dinan at mcs.anl.gov
Mon Jan 31 11:07:01 CST 2011
Hi Michele,
I'm looking this over and trying to put together a test case from the
code you sent.  One thing that looks questionable is the type for 'ext'.
  The call to mpi_type_size wants an integer, however the
mpi_type_create_resized calls want an integer of kind=MPI_ADDRESS_KIND.
  Could you try adding something like this:
   integer :: dcsize
   integer (kind=MPI_ADDRESS_KIND) :: ext
   call mpi_type_size( mpi_double_complex , dcsize , errorMPI)
   ext = dcsize
  ~Jim.
On 01/30/2011 02:15 AM, Michele Rosso wrote:
> Hi,
> I am developing a subroutine to handle the communication inside a group
> of processors.
> The source code is attached.
> Such subroutine is contained in a module and accesses many of the data
> it needs and the header "mpi.h" from another module (pmu_var).
> As an input I have a 3D array (work1) which is allocated in the main
> program. As an output I have another 3D matrix (work2) which is
> allocated in the main program too. Both of them are of type complex and
> have intent INOUT (I wanna use the subroutine in a reversible way ).
> Since the data I wanna send are not contiguous, I defined several data
> types. Then I tested all of them with a simple send-receive
> communication in the group "mpi_comm_world".
> The problem arises when I tested the data type "temp3": the esecution of
> the program stops and I receive the error:
> rank 0 in job 8  enterprise_45569   caused collective abort of all ranks
>    exit status of rank 0: killed by signal 9
> Notice that work1 and work2 have different size but the same shape and
> the data type should be coherent with them.
> Has anyone and idea of which the problem could be?
> Thanks in advance,
> Michele
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
