[mpich-discuss] error in MPI_INIT on 64 bit machine
Cugnon
frederic.cugnon at samtech.com
Tue Jan 25 09:10:58 CST 2011
Hi
I have been using MPICH2 to implement co-simulation between Matlab Simulink
and my code. I have implemented a master-slave procedure, launching my code
from a Matlab S-function using MPI_Comm_spawn. Things are working perfectly
on an old Windows XP computer with 32 bit version of both softwares. When I
move to 64 bit versions on Windows Seven system, I have errors when the
slave process calls the MPI_Init function. Depending on the communication
channel that I use (sock or nemesis), I get slightly different error
messages when MPI_Init is called (see attached log files).
Could anybody help me with this problem?
Thanks
Frédéric CUGNON
Samtech SA
Rue des Chasseurs-Ardennais 8
4031 Angleur
tel int-32-4-361.69.69
fax int-32-4-361.69.80
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110125/7e69126a/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110125/7e69126a/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110125/7e69126a/attachment-0003.obj>
