[mpich-discuss] using mpiexec as a dll
Prashanth prashanth.dumpuri at gmail.com
Mon Jan 24 16:48:07 CST 2011
Thanks again Jayesh. If MPI_Comm_spawn can spawn a dll (instead of a
program/application) then this is what I want. I'll try it and let you
know.
P.S: In order for my code to run do not want spawn a child process / create
another executable from the main project's exe. I'm a newbie and am still
learning the jargon. So pardon me if I used the words 'spawning' and 'child
process' incorrectly.
On Mon, Jan 24, 2011 at 4:41 PM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
>  You can take a look at MPI Dynamic processes (MPI_Comm_spawn()) to spawn
> additional processes from your MPI process. Is that what you are looking for
> Regards,
> Jayesh
> From: "Prashanth" <prashanth.dumpuri at gmail.com>
> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>, mpich-discuss at mcs.anl.gov
> Sent: Monday, January 24, 2011 4:22:06 PM
> Subject: Re: [mpich-discuss] using mpiexec as a dll
> Jayesh,
> Thanks for your immediate response. I have successfully built a DLL from my
> code (instead of an exe) and have integrated the DLL into the existing
> project's exe. I have to run the project exe on one processor and when
> invoked i have to run my code on multiple processors. How do i tell my DLL
> to use multiple processors and how do I know which processor is running the
> code? The only way I know how to do that is to use mpiexec -n 2 and this
> tells MPI_Comm_size that I have 2 processors and MPI_Comm_rank to get the
> rank of the current processor.
> Thanks
> Prashanth
> On Thu, Jan 20, 2011 at 3:30 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> You should be able to run an MPI process as a singleton process (without
> mpiexec). Try running your program from the command prompt without mpiexec
> and let us know if you have any issues.
> (PS: The singleton process should also be able to spawn MPI processes.)
> Regards,
> Jayesh
> From: "Prashanth" < prashanth.dumpuri at gmail.com >
> To: mpich-discuss at mcs.anl.gov
> Sent: Thursday, January 20, 2011 2:40:59 PM
> Subject: [mpich-discuss] using mpiexec as a dll
> All,
> I have to integrate my code which requires MPICH2 - into an existing
> project as a dll. Ideally I would not want to spawn a child process for my
> code. In other words I do not want my code's dll to run mpiexec.exe as a
> background or child process. Is there a way to execute a MPI program without
> having to invoke mpiexec.exe? (I'm running MPICH2 on Windows XP)
> Thanks
> Prashanth
> mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110124/a1874b41/attachment.htm>
