[mpich-discuss] using mpiexec as a dll
Jayesh Krishna jayesh at mcs.anl.gov
Mon Jan 24 16:41:21 CST 2011
 You can take a look at MPI Dynamic processes (MPI_Comm_spawn()) to spawn additional processes from your MPI process. Is that what you are looking for ?
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>, mpich-discuss at mcs.anl.gov
Sent: Monday, January 24, 2011 4:22:06 PM
Subject: Re: [mpich-discuss] using mpiexec as a dll
Jayesh,
Thanks for your immediate response. I have successfully built a DLL from my code (instead of an exe) and have integrated the DLL into the existing project's exe. I have to run the project exe on one processor and when invoked i have to run my code on multiple processors. How do i tell my DLL to use multiple processors and how do I know which processor is running the code? The only way I know how to do that is to use mpiexec -n 2 and this tells MPI_Comm_size that I have 2 processors and MPI_Comm_rank to get the rank of the current processor.
Thanks
Prashanth
On Thu, Jan 20, 2011 at 3:30 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
You should be able to run an MPI process as a singleton process (without mpiexec). Try running your program from the command prompt without mpiexec and let us know if you have any issues.
(PS: The singleton process should also be able to spawn MPI processes.)
Jayesh
From: "Prashanth" < prashanth.dumpuri at gmail.com >
Sent: Thursday, January 20, 2011 2:40:59 PM
Subject: [mpich-discuss] using mpiexec as a dll
All,
I have to integrate my code which requires MPICH2 - into an existing project as a dll. Ideally I would not want to spawn a child process for my code. In other words I do not want my code's dll to run mpiexec.exe as a background or child process. Is there a way to execute a MPI program without having to invoke mpiexec.exe? (I'm running MPICH2 on Windows XP)
Thanks
Prashanth
mpich-discuss mailing list
