[mpich-discuss] process/core binding
Pavan Balaji
balaji at mcs.anl.gov
Thu Jan 13 08:31:47 CST 2011
Hi Mark,
You can either use a user-defined mapping or Hydra's CPU topology
functionality.
See
http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager#Process-core_Binding
The following options should work:
/* Use appropriate values for x, y */
% mpiexec -np 2 -binding user:<x,y> ./foo
or
% mpiexec -np 2 -binding cpu:sockets ./foo
Note, however, that there were some bugs in mpich2-1.3.1 in this part of
the code which got fixed after the release. So, if things don't appear
to work correctly, I'd recommend using the latest nightly snapshot.
http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/hydra
These fixes should be available in the upcoming 1.3.2 release as well.
-- Pavan
On 01/13/2011 08:00 AM, Mark Beauharnois wrote:
> Hi,
> Seems like my previous email was truncated after the table so I’ll repost…
> I have a 2x Quad core Intel Nehalem server, and /proc/cpuinfo shows the
> following processing element mapping (16 virtual processing elements I
> guess due to Intel’s Hyperthreading architecture):
> Physical ID 0 Physical ID 1
> Proc Id/Core Id Proc Id/Core Id
> 0/0 4/0
> 1/1 &n sp; 5/1
> 2/9 6/9
> 3/10 7/10
> 8/0 12/0
> 9/1 13/1
> 10/9 &nb sp; o:p>
> 11/10 15/10
> I would like to run 2 processes on the machine, and insure that each
> physical CPU runs one process. By default, does Hydra distribute the two
> processes over the physical CPU’s, or would it run the two processes on
> processor ID’s 0, and 1 (2 cores on same physical processor)? If that is
> true, how would I specify a user defined process/core binding in this
> situation to make sure that the processes are distributed across
> physical CPU’s? Would I use a binding such as “binding=user:0,4”?
> Thanks,
> Mark
> Mark Beauharnois
> Atmospheric Sciences Research Center
> State University of New York at Albany
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
