[mpich-discuss] Assertion failure from too many MPI_Gets between fences
Dave Goodell
goodell at mcs.anl.gov
Fri Jan 7 16:46:41 CST 2011
On Jan 7, 2011, at 4:03 PM CST, Jeremiah Willcock wrote:
> On Fri, 7 Jan 2011, Dave Goodell wrote:
>>>> On Jan 7, 2011, at 12:56 PM CST, Jeremiah Willcock wrote:
>> Not off the top of my head. It seems like you are using a small-ish test program to check this. Can you send that to me so that I can reproduce this for myself and play with the bug?
> I don't really have a small program for this, just part of a larger one that I was putting print statements in and hacking on. The relevant part of the code just creates a window for an array (with different data on different ranks) then does MPI_Gets on random parts of it to implement a large gather operation. A code such as row-distributed sparse matrix-vector multiplication would have this kind of access pattern as well.
I won't be able to dig into this today, so I've created a ticket to track this: https://trac.mcs.anl.gov/projects/mpich2/ticket/1156
>>> Inserting fences periodically in my code fixes the problem, but the fence frequency needed is proportional to the number of ranks in the job. I think the MPI implementation should automatically do whatever flow control it needs to avoid running out of memory, no matter how many requests the application feeds in.
>> I agree, the MPI implementation should take care of that, within reason. But forcing an MPI_Get to be nonblocking will require a careful reading of the MPI standard to ensure that's valid behavior. I think I can construct scenarios where an MPI_Get that blocks would cause a deadlock...
> I believe (like everything else in MPI) they can be nonblocking or blocking, at the implementation's choice, but I don't know for sure. Remember that you can't assume that a get has completed until the next fence, so you can't depend on seeing the answer (which I think was what you were worried about causing deadlocks). I treat the MPI_Gets as nonblocking in my application; that's why I start a large number of them then use a fence to complete them all before using the results.
MPI-2.2, page 339, line 13-14: "These operations are nonblocking: the call initiates the transfer, but the transfer may continue after the call returns."
This language is weaker than I would like, because the presence of the clarifying statements after the colon don't say that the call cannot block, implicitly watering down the natural MPI meaning of "nonblocking". But I think that the intent is clear, that the call should not block the user waiting on the action of another process. After further thought I can't come up with any realistic example where a blocking-for-flow-control MPI_Get causes a deadlock, but I think the behavior is still intended to be disallowed by the standard.
>> Without knowing exactly why it's failing, other than some sort of request allocation problem, it's hard to say what the right fix is.
> Is there a patch I could apply to MPICH to help diagnose the problem? A branch I could switch to for testing?
Eventually, but nothing that I have cooked up already.
-Dave
