[mpich-discuss] Assertion failure from too many MPI_Gets between fences
    Jeremiah Willcock
    jewillco at osl.iu.edu
    Fri Jan  7 16:03:24 CST 2011
On Fri, 7 Jan 2011, Dave Goodell wrote:
>>> On Jan 7, 2011, at 12:56 PM CST, Jeremiah Willcock wrote:
>>>> on some or all ranks.  I am using the SVN head version currently, but the same error (and same line number) occurred with 1.3.1.  I am running two processes on one machine using "mpiexec -n 2 app"; the platform is x86-64 Linux (RHEL 5.5, gcc 4.1.2).  The number of MPI_Get operations required seems to be about 260k; fewer appears to work fine, but the exact number required for the error varies.  The kind of code I am using is:
>>> 260k is a large number of requests, if one req is being allocated for
>>> each Get.  Requests are unfortunately large, somewhere on the order of
>>> 1 kiB, so 260k reqs is in the neighborhood of 260 MiB of memory,
>>> possibly double that if I'm lowballing the request size.  The handle
>>> allocator has a theoretical capacity of at least 2^26 bits (~67
>>> million), so I don't think that we hit an intrinsic addressing limit.
>>> Is your application memory-constrained?
>> Not really, at least at the sizes I'm testing at so far.  Is there a
>> good way to test how much memory it is actually using, or how much
>> memory MPICH is using?
> Not off the top of my head.  It seems like you are using a small-ish
> test program to check this.  Can you send that to me so that I can
> reproduce this for myself and play with the bug?
I don't really have a small program for this, just part of a larger one
that I was putting print statements in and hacking on.  The relevant part
of the code just creates a window for an array (with different data on
different ranks) then does MPI_Gets on random parts of it to implement a
large gather operation.  A code such as row-distributed sparse
matrix-vector multiplication would have this kind of access pattern as
well.
>> Inserting fences periodically in my code fixes the problem, but the
>> fence frequency needed is proportional to the number of ranks in the
>> job.  I think the MPI implementation should automatically do whatever
>> flow control it needs to avoid running out of memory, no matter how
>> many requests the application feeds in.
> I agree, the MPI implementation should take care of that, within reason.
> But forcing an MPI_Get to be nonblocking will require a careful reading
> of the MPI standard to ensure that's valid behavior.  I think I can
> construct scenarios where an MPI_Get that blocks would cause a
> deadlock...
I believe (like everything else in MPI) they can be nonblocking or
blocking, at the implementation's choice, but I don't know for sure.
Remember that you can't assume that a get has completed until the next
fence, so you can't depend on seeing the answer (which I think was what
you were worried about causing deadlocks).  I treat the MPI_Gets as
nonblocking in my application; that's why I start a large number of them
then use a fence to complete them all before using the results.
> Without knowing exactly why it's failing, other than some sort of
> request allocation problem, it's hard to say what the right fix is.
Is there a patch I could apply to MPICH to help diagnose the problem?  A
branch I could switch to for testing?
-- Jeremiah Willcock
