[mpich-discuss] Strange MPI problem
Jayesh Krishna jayesh at mcs.anl.gov
Sun Jan 2 23:01:27 CST 2011
 Can you send us a sample code that shows the problem ?
(PS: The error messages that you get are from the MPICH2 process manager)
Jayesh
----- Original Message -----
Sent: Sun, 02 Jan 2011 22:57:18 -0600 (CST)
Subject: [mpich-discuss] Strange MPI problem
Hi MPI people,
I am now learning MPI programming. My code is something like this:
int main(int argc, char* argv[])
MPI_Init(&argc,&argv);
MPI_Comm_size(MPI_COMM_WORLD,&numprocs);
MPI_Comm_rank(MPI_COMM_WORLD,&rank);
if(rank != 0)
     //workers do something here
    // no other MPI runtiness are used
MPI_Finalize();
return 0;
I start 14 processes on four machines to run this programs. However, my
programs seems halt on MPI_Finalize(). I check the log and find these error
information.
[03:5784]......ERROR:result command received but the wait_list is empty.
[03:5784]....ERROR:unable to handle the command: "cmd=result dfsrc=0 dest=3
tag=32 cmd_tag=21 ctx_key=1 result=SUCCESS "
[03:5784]..ERROR:error closing the unknown context socket: Error = -1
May I know what does these error log mean? These error log occurr at the end
of my main function, just before the last statement "return 0". As I do not
use any MPI communication routines in side the code block, I do not know why
does these error happen. By the way, I am sure the example program cpi.exe
works fine on my small cluster. The cluster is composed by four Windwos XP
sp2 machines connected by 100Mbps localnetwork.
cheers
Xiao
