[mpich-discuss] problem with installing mpich2-1.4.1
    Anthony Chan
    chan at mcs.anl.gov
    Thu Aug 25 11:48:27 CDT 2011
Besides what Dave said, your c.txt also indicates that your f95 wasn't
working with your f77 (probably because it is an old machine and f95 is
installed later).  If you don't need Fortran 90 support, add --disable-fc
as part of your configure command.
A.Chan
checking whether the Fortran 90 compiler (f95    ) works... configure: WARNING: installation or configuration problem: Fortran 90 compiler cannot create executables.
checking whether Fortran 90 compiler works with Fortran 77 compiler... configure: WARNING: See config.log for the failed test program and its output.
no
configure: WARNING: The selected Fortran 90 compiler f95 does not work with the selected Fortran 77 compiler f77.  Use the environment variables FC and F77 respectively to select compatible Fortran compilers.  The check here tests to see if a main program compiled with the Fortran 90 compiler can link with a subroutine compiled with the Fortran 77 compiler.
----- Original Message -----
> On Aug 25, 2011, at 9:46 AM CDT, Xiao-lin Nick Wu wrote:
> > I tried to install mpich2-1.4.1 on our workstations. It worked well
> > except on one machine. On that machine, it passed the configuration
> > but gave error message when I tried to build it. Attached are two
> > files: c.txt and m.txt. Please let me know how I can fix it.
> The problem looks like string.h on your system #defines strncmp to
> some inline macro but MPICH2 attempts to provide a "missing" prototype
> for strncmp. The prototype probably isn't actually missing, the
> PAC_FUNC_NEEDS_DECL configure macro is probably broken instead in this
> sort of environment.
> Can you send us the "config.log" file from your build as well? That
> will help us confirm and fix the problem.
> I feel like we've encountered this and dealt with it before in some
> way, but I can't remember anything specific and I didn't find anything
> by googling and searching my email archives.
> -Dave
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
