[mpich-discuss] mpi runtime error
nilima natoo
nilima.2002 at gmail.com
Mon Aug 22 15:06:52 CDT 2011
Dear Ashok and Anthony, thanks very much for your kind help.
I could now solve this error.
best wishes,
Nilima
On Fri, Aug 19, 2011 at 8:55 PM, Ashok Vignesh K <
ashok.vignesh at googlemail.com> wrote:
> Dear Nilima Natoo,
> Where is the location of oceanM file? Can you try the command "which
> oceanM" if not there. Go to oceanM file folder and where is the input file?
> Copy the input file to oceanM file folder then you can try to run your
> parallel program --> mpirun -np 4 ./oceanM coupling_inlet_test.in
> Hope this explains.
> Regards,
> Ashok Vignesh K
> On 19 August 2011 20:41, nilima natoo <nilima.2002 at gmail.com> wrote:
>> Dear friends,
>> I have following errors, and these seem to be related with MPI libraries.
>> I use MPICH2-version 1.4. I am trying to run a test case where ROMS and SWAN
>> models need to be coupled using MCT.
>> [nma at k6 inlet_test]$ mpirun -np 4 oceanM coupling_inlet_test.in
>> [proxy:0:0 at k6] HYDU_create_process (./utils/launch/launch.c:69): execvp
>> error on file oceanM (No such file or directory)
>> kindly advice if I am making basic mistakes in using MPI...
>> thanks and regards, nma
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110822/6fbc31b3/attachment.htm>
