[mpich-discuss] Running MPI jobs without mpiexec
    Amar K. Patel
    PATEL_AMAR_K at cat.com
    Mon Aug 15 10:58:37 CDT 2011
Hi Jayesh,
Thanks for suggesting the two options earlier. I have been exploring them
since your recommendations and I would appreciate if you could answer
these follow-up questions.
1. I have been looking at MPI_Comm_spawn_multiple and MPI_Comm_spawn under
MPI dynamic processes and I have concluded that for either of these
options to work, the callee binary should be an exe. Am I correct to
conclude this?
Meaning that if I have the following line in my main code (call it
myCode2.exe),
MPI_Comm_spawn_multiple(NHOST, progs, MPI_ARGVS_NULL, nproc, infos, 0,
MPI_COMM_WORLD, &intercomm, MPI_ERRCODES_IGNORE);
the binary specified under "Progs" argument should be an exe and not a dll
or a lib file. Is this correct ?
Here is a little background on what I am trying to do here.
I am trying to call a shared library (dll) that needs to be run on
multiple processors but I do not want the main calling program to be run
on multiple PCs. So basically, I need to run the main program
(myCode2.exe) as a singleton process which at run time needs to call a dll
(myCode1.dll) and that dll needs to be run on multiple processors.
I have tried putting in MPI_Comm_spawn_multiple in the main program and
tried to call the dll through MPI_Comm_spawn_multiple but I get a runtime
error indicating that the program being called by MPI_Comm_spawn_multiple
is not an executable.
2. Your other suggestion was launching mpiexec from the main program
(myCode2.exe). Are you suggesting using the system() function in
myCode2.exe to launch mpiexec which then launches myCode1?  Wont this
require myCode1 to be an exe file to be launched with mpiexec command? In
my case myCode1 used to be compiled as a standalone exe file before, but
we would now wish to compile it as a dll that is loaded as a shared
library and called by another larger executable at run time.
Thanks for your help.
Amar
Jayesh Krishna <jayesh at mcs.anl.gov>
Sent by: mpich-discuss-bounces at mcs.anl.gov
08/04/2011 03:28 PM
Please respond to
mpich-discuss at mcs.anl.gov
To
cc
Subject
Re: [mpich-discuss] Running MPI jobs without mpiexec
Caterpillar: Confidential Green Retain Until: 09/03/2011
 Two options come to my mind,
# Take a look at MPI dynamic processes (
http://www.mpi-forum.org/docs/mpi21-report/node197.htm#Node197).
# Launch mpiexec from myCode2.
Jayesh
----- Original Message -----
Sent: Thursday, August 4, 2011 11:35:58 AM
Subject: [mpich-discuss] Running MPI jobs without mpiexec
Hello,
I have MPI program that runs fine when it started with the command mpiexec
-n # myCode1.exe. I now need to call myCode1 from another code (say
myCode2) in such a way that myCode1 is a dll file which is loaded and
called when myCode2 is being executed. myCode2 is started without using
mpiexec commad.
With this new setup I would like to call myCode1.dll and be able to use
the MPI features that have been embedded in it such that myCode1.dll can
be run on more than one CPU. Is such a thing possible ? If so, then I
would appreciate if someone could point me to a documentation or an
example that illustrates how to implement the changes needed in myCode1
and/or myCode2.
Here is an crude version of myCode1 and myCode2 that I am using.
void myCode1()
int rank;
MPI_Init(x, x);
MPI_Comm_rank(MPI_COMM_WORLD, &rank);
MPI_Finalize();
return;
int myCode2(int argc, char **argv)
myCode1();
return 0;
mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110815/48d713ab/attachment.htm>
