[mpich-discuss] Fwd: compiling parallel programms with ifort
mohamed ali eng1182 at gmail.com
Wed Apr 27 13:30:49 CDT 2011
Dear there
I have installed MPICH2-1.3.2p1 on ubuntu and the installation was ended and
tested successfully, When  i try to compile a parallel program with ifort,
it gives me error. i use this command for compiling:
ifort heat_mpi.f90 hi.out -o
the errors that appear are as follows:
/tmp/ifortYgvRCy.o: In function `MAIN__':
heat_mpi.f90:(.text+0x1f8): undefined reference to `mpi_init_'
heat_mpi.f90:(.text+0x214): undefined reference to `mpi_comm_rank_'
heat_mpi.f90:(.text+0x230): undefined reference to `mpi_comm_size_'
heat_mpi.f90:(.text+0x255): undefined reference to `mpi_wtime_'
heat_mpi.f90:(.text+0x1166): undefined reference to `mpi_send_'
heat_mpi.f90:(.text+0x11ce): undefined reference to `mpi_recv_'
heat_mpi.f90:(.text+0x1236): undefined reference to `mpi_send_'
heat_mpi.f90:(.text+0x1294): undefined reference to `mpi_recv_'
heat_mpi.f90:(.text+0x149f): undefined reference to `mpi_wtime_'
heat_mpi.f90:(.text+0x1590): undefined reference to `mpi_finalize_'
/tmp/ifortYgvRCy.o: In function `update_':
heat_mpi.f90:(.text+0x27f9): undefined reference to `mpi_send_'
heat_mpi.f90:(.text+0x2858): undefined reference to `mpi_recv_'
heat_mpi.f90:(.text+0x28b7): undefined reference to `mpi_send_'
heat_mpi.f90:(.text+0x2911): undefined reference to `mpi_r
i have included the mpif.h file in the same directory and i added the paths
of mpich2/include and mpich2/lib to the PATH variable. should i change some
thing in my command? or do some thing to define the mpich2 to ifort. I had
the ifort installed befor mpich2.
thanks,
Ali.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110427/3f7a9355/attachment.htm>
