[mpich-discuss] multi-core processores
Nicolas Rosner nrosner at gmail.com
Wed Apr 27 09:27:14 CDT 2011
Hello Ali,
You can use the -np (or just -n, same thing) option to tell mpiexec
the number of desired processes, e.g.
    mpiexec -np 4 your_program
By default, if you don't specify a list of nodes, the above syntax
will usually launch four copies of your_program on the local machine.
Further details:
  * mpiexec -help
  * http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
  * http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs
Hope this helps,
Nicolás
On Wed, Apr 27, 2011 at 10:19 AM, Mohamed Ali Abd El Aziz Essa
<moalab at upvnet.upv.es> wrote:
> Dear there
> We are here in the university of Valencia, Spain. have installed mpich2 with
> intel fortran compiler. we'd like to make use of multi-core intel. how it can
> be defined for the mpiexec that the processor have 4 cores and to make use of
> theme.
> with my regards,
> Ali.
> Instituto de Ingenieria Energetia
> Ciudad Plitecnica de Inovacion
> Universidad Politecnica de Valencia
> 8E edeficio, accesso F, 5ª planta
> Camino de Vera s/n
> 46022 Valencia
> España
> Tel.: +34 963 87 91 23 (ext 79123)
> Fax: +34 963 87 91 26
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
