[mpich-discuss] configure.in:860: error: possibly undefined macro: AC_CXX_NAMESPACE_STD
Jeff Hammond
jeff.science at gmail.com
Fri Apr 8 09:15:24 CDT 2011
Because I wasn't paying attention to the fact that maint/updatefiles
included the effects of autoreconf, which is of course a bad reason.
I'll not do this anymore.
Jeff
On Fri, Apr 8, 2011 at 8:59 AM, Anthony Chan <chan at mcs.anl.gov> wrote:
> Jeff,
> updatefiles seems to finish normally. I don't see the unresolved
> AC macro message around test/mpi. Why do you want to run autoreconf
> instead of maint/updatefiles on mpich2 trunk ?
> A.Chan
>> See attached. It is rather large.
>> Thanks,
>> Jeff
>> On Thu, Apr 7, 2011 at 8:01 PM, Anthony Chan <chan at mcs.anl.gov> wrote:
>> > Could you send us the output of maint/updatefiles ?
>> > A.Chan
>> >> jeff at megatron:/software/mpich/mpich2-trunk> autoreconf -vif
>> >> autoreconf: Entering directory `.'
>> >> autoreconf: configure.in: not using Gettext
>> >> autoreconf: running: aclocal --force
>> >> autoreconf: configure.in: tracing
>> >> autoreconf: configure.in: adding subdirectory test/mpi to
>> >> autoreconf
>> >> autoreconf: Entering directory `test/mpi'
>> >> autoreconf: configure.in: not using Libtool
>> >> autoreconf: running: /usr/local/bin/autoconf --force
>> >> If this token and others are legitimate, please use
>> >> m4_pattern_allow.
>> >> See the Autoconf documentation.
>> >> autoreconf: /usr/local/bin/autoconf failed with exit status: 1
>> >> jeff at megatron:/software/mpich/mpich2-trunk> autoreconf -V
>> >> autoreconf (GNU Autoconf) 2.68
>> >> Copyright (C) 2010 Free Software Foundation, Inc.
>> >> License GPLv3+/Autoconf: GNU GPL version 3 or later
>> >> <http://gnu.org/licenses/gpl.html>,
>> >> <http://gnu.org/licenses/exceptions.html>
>> >> This is free software: you are free to change and redistribute it.
>> >> There is NO WARRANTY, to the extent permitted by law.
>> >> Written by David J. MacKenzie and Akim Demaille.
>> >> Jeff Hammond
>> >> Argonne Leadership Computing Facility
>> >> jhammond at alcf.anl.gov / (630) 252-5381
>> >> http://www.linkedin.com/in/jeffhammond
>> >> _______________________________________________
>> >> mpich-discuss mailing list
>> >> mpich-discuss at mcs.anl.gov
>> >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> Jeff Hammond
Jeff Hammond
