[mpich-discuss] configure.in:860: error: possibly undefined macro: AC_CXX_NAMESPACE_STD
Anthony Chan
chan at mcs.anl.gov
Fri Apr 8 08:59:12 CDT 2011
Jeff,
updatefiles seems to finish normally. I don't see the unresolved
AC macro message around test/mpi. Why do you want to run autoreconf
instead of maint/updatefiles on mpich2 trunk ?
A.Chan
----- Original Message -----
> See attached. It is rather large.
> Thanks,
> Jeff
> On Thu, Apr 7, 2011 at 8:01 PM, Anthony Chan <chan at mcs.anl.gov> wrote:
> > Could you send us the output of maint/updatefiles ?
> > A.Chan
> >> jeff at megatron:/software/mpich/mpich2-trunk> autoreconf -vif
> >> autoreconf: Entering directory `.'
> >> autoreconf: configure.in: not using Gettext
> >> autoreconf: running: aclocal --force
> >> autoreconf: configure.in: tracing
> >> autoreconf: configure.in: adding subdirectory test/mpi to
> >> autoreconf
> >> autoreconf: Entering directory `test/mpi'
> >> autoreconf: configure.in: not using Libtool
> >> autoreconf: running: /usr/local/bin/autoconf --force
> >> If this token and others are legitimate, please use
> >> m4_pattern_allow.
> >> See the Autoconf documentation.
> >> autoreconf: /usr/local/bin/autoconf failed with exit status: 1
> >> jeff at megatron:/software/mpich/mpich2-trunk> autoreconf -V
> >> autoreconf (GNU Autoconf) 2.68
> >> Copyright (C) 2010 Free Software Foundation, Inc.
> >> License GPLv3+/Autoconf: GNU GPL version 3 or later
> >> <http://gnu.org/licenses/gpl.html>,
> >> <http://gnu.org/licenses/exceptions.html>
> >> This is free software: you are free to change and redistribute it.
> >> There is NO WARRANTY, to the extent permitted by law.
> >> Written by David J. MacKenzie and Akim Demaille.
> >> Jeff Hammond
> >> Argonne Leadership Computing Facility
> >> jhammond at alcf.anl.gov / (630) 252-5381
> >> http://www.linkedin.com/in/jeffhammond
> >> _______________________________________________
> >> mpich-discuss mailing list
> >> mpich-discuss at mcs.anl.gov
> >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Jeff Hammond
