[mpich-discuss] hydra and mpich2-1.3rc1
    Bryan Putnam
    bfp at purdue.edu
    Thu Sep 23 10:37:43 CDT 2010
On Thu, 23 Sep 2010, Pavan Balaji wrote:
> Hi Bryan,
> Yup, I can reproduce the bug now. See below for more information.
> > $MPI_SRC/configure \
> >  --with-device=ch3:nemesis \
> >  --enable-fast \
> >  --enable-threads \
> >  --enable-debuginfo \
> >  --enable-shared \
> >  --enable-sharedlibs=gcc \
> >  --enable-f77 \
> >  --enable-fc \
> >  --enable-cxx \
> >  --enable-romio \
> >  --with-pm=mpd:hydra \
> >  --without-mpe \
> >  --prefix=$MPI_INSTALL/$CVER \
> >  > configure.log 2>&1
> You still seem to be forcing MPD to be the default process manager, and
> hydra to be the secondary PM. If you remove the --with-pm=... line, you
> can get hydra by default. This case should work correctly.
> The problem you are seeing is because of a combination of
> --enable-shared and using Hydra as the secondary PM. In this case,
> libtool wants us to use "make install" to install mpiexec executable.
> However, since both MPD and Hydra will create an mpiexec executable,
> just doing "make install" directly will cause one of them to overwrite
> the mpiexec created by the other. We had some workaround for this in
> src/pm/hydra/Makefile.am (see the install-alt target, which tries to
> rename mpiexec to mpiexec.hydra), but that's clearly not sufficient for
> shared library builds where libtool wants to manage the executables.
> I'll try to workaround this problem and commit a patch soon.
Pavan,
Thanks, omitting "--with-pm=..." in mpich2-1.3rc1 fixed the problem. I
think this configure appeared to work with mpich2-1.3b1 because I had not
specified the "--with-shared" config option. However, in mpich2-1.3rc1,
"--with-shared" was required in order to use "--with-sharedlib=gcc".
Bryan
>  -- Pavan
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
