[mpich-discuss] ad_zoidfs
Dries Kimpe
dkimpe at mcs.anl.gov
Wed Sep 22 17:04:19 CDT 2010
Hi Rico,
does the same thing happen if you compile a small MPI(-IO) program?
I'm not sure if we ever tried running the romio tests, so maybe the
Makefile for the test directory needs to be adjusted to work with IOFSL.
(Especially since the tests in there probably link against the source
tree, not against the installed MPI libraries and so might require some
custom paths)
Dries
* Rico J. D amore <rjdamore at lanl.gov> [2010-09-21 15:02:15]:
> Hello all,
> I'm in the process of trying to figure out the ROMIO/ADIO layer for zoidfs.
> I'm currently trying to compile simple test in
> Mpich2-1.3a2/src/mpi/romio/test. I get an incorrect linking message for
> the zoidfs libs. as follows:
> /users/rjdamore/mpich-install/lib/libmpich.a(ad_zoidfs_delete.o)(.text+0x3d):
> In function `ADIOI_ZOIDFS_Delete':
> : undefined reference to `zoidfs_remove'
> It prints this out for the whole zoidfs_api...
> I have my zoidfs libs correctly linked or so I think. And I set the
> CFLAGS as the iofsl build page describes:
> setenv CFLAGS "-I$HOME/iofsl/build/iofsl-install/include"
> setenv LDFLAGS "-L$HOME/iofsl/build/iofsl-install/lib"
> setenv LIBS "-lzoidfs -lzoidfsclient -lzoidfshints -lzoidfsprofile
> -lzoidfsrouter -lzoidfs-util"
> Has anyone seen this problem??
> Your insight is welcome!
> Thanks,
> Rico D'Amore
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100922/2c6b3e64/attachment.pgp>
