[mpich-discuss] I have a question
    sc Deng
    dengsc74.sj at gmail.com
    Tue Sep 21 17:42:41 CDT 2010
Dear Mr. Chan,
   I will try it according to your instruction. Thank you very much.
On Tue, Sep 21, 2010 at 4:37 PM, Anthony Chan <chan at mcs.anl.gov> wrote:
> It appears your fortran code has an illegal access of memory.
> Since you are using intel fortran compiler and assuming you have access
> to the source code, recompile the code with -traceback (and probably -g)
> which will display a backtrace of where segfault occurs.
> A.Chan
> ----- "sc Deng" <dengsc74.sj at gmail.com> wrote:
> > Dear all,
> >   I meet a question in using MPICH2, the error is as follows,
> > TimeStep =    3500  Time = 0.1050E+04
> >   Total E =  85.3849     Pot E =  81.9326     Kin E =  3.45222
> >   Temp = 0.702334E-04 Pressure =-0.789195E-04 Volume =  191110.
> >   Box =  57.7138      57.4711      57.6176
> > forrtl: severe (174): SIGSEGV, segmentation fault occurred
> > Image              PC                Routine            Line
> > Source
> > DEM_Linux.out      000000000046FAE6  Unknown               Unknown
> > Unknown
> > Stack trace terminated abnormally.
> > rank 1 in job 5  fn-148-148_54121   caused collective abort of all
> > ranks
> > exit status of rank 1: killed by signal 9
> > It is a 3D Distinct element code, the error appears after computing
> > 3500
> > time steps, but it is OK for 2D simulation or just 1 processor for
> > 3D.
> > Please let me know if anyone has the corresponding experience. Thank
> > you
> > very much.
> > Your sincerely,
> > Shouchun Deng
> > _______________________________________________
> > mpich-discuss mailing list
> > mpich-discuss at mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Your sincerely,
Shouchun Deng
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100921/d164ffc8/attachment.htm>
