[mpich-discuss] Error while making MPICH2
Dave Goodell
goodell at mcs.anl.gov
Wed Sep 8 13:46:53 CDT 2010
There are some strange "permission denied" errors during the MPE and MPD builds at the end of your m.txt. But it's not obvious to me what is causing that.
What exact commands did you execute? Did you execute them as a normal user or as root (only "make install" should be done as root)? Is this a VPATH build (invoking configure from a different directory than the source tree)? Can you please also attach your config.log?
Did you actually run "sudo make install" after the make step?
-Dave
On Sep 7, 2010, at 2:00 PM CDT, Alejandro Campos wrote:
> Hi,
> I'm trying to install MPICH2 on Mac OS 10.6 but I'm getting errors after running the make command. The source directory is in my downloads folder, and I'm trying to install MPICH in /usr/local/mpich. After running make nothing appears in this folder.
> I'm attaching the m.txt and c.txt files and was wondering if I could please get some help.
> Thank you very much,
> Alejandro<m.txt><c.txt>_______________________________________________
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
