[mpich-discuss] cryptic (to me) error
SULLIVAN David (AREVA) David.Sullivan at areva.com
Tue Sep 7 12:40:33 CDT 2010
Had some time to work some more on this...
I have copied the test suit folder in a NFS shared folder. The machine
file is passed by way of HYDRA_HOST_FILE=/home/dfs/shared/mpich2 make
testing, as suggested. It is still running, but the results so far
indicate I am still messing up the process somehow.
Thanks again,
Dave
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
Sent: Friday, September 03, 2010 2:56 PM
Subject: Re: [mpich-discuss] cryptic (to me) error
Based on what you've sent us in the past, your mpiexec is actually
running mcnp.mpi.  The error occurs during an MPI_Comm_dup somewhere in
that code.  Running the test suite over the network will help us figure
out whether there is a problem with your network.
-Dave
On Sep 3, 2010, at 1:50 PM CDT, SULLIVAN David (AREVA) wrote:
> That makes sense. Since my real problem is that mpiexec doesn't get to
> starting mcnp.mpi do we need the testing suite to troubleshoot or is
> there a source of clues elsewhere? I can get an NFS set up and all,
> but the testing suite isn't my true aim so if we don't need it...
> Dave
> From: mpich-discuss-bounces at mcs.anl.gov
> Sent: Friday, September 03, 2010 2:47 PM
> The general statement is true.  The problem is that "make testing"
> does not first build all executables and then second mpiexec each
executable.
> Instead it builds each test  (on the machine where you invoked "make
> testing")  just before it is executed.  So the built executables only
> end up on the node where you ran "make testing".
> -Dave
> On Sep 3, 2010, at 1:43 PM CDT, SULLIVAN David (AREVA) wrote:
>> Interesting. So that would be the same for any executable that uses
>> mpiexec? This is confusing though because the install guide says that
>> it can be done either as NFS or a exact duplicate. I have set this up
>> before (as exact duplicates) without issues (with MPICH1 on WinXP) so
>> I assumed, as it states in the install guide, this has not changed.
>> Thanks again for the remedial assistance..
>> Dave
>> Sent: Friday, September 03, 2010 2:03 PM
>> The test suite directory must be on a shared filesystem because
>> mpiexec does not stage executables for you.
>> -Dave
mpich-discuss mailing list
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100907/efa6f0d7/attachment-0001.txt>
