[mpich-discuss] cryptic (to me) error
    Dave Goodell
    goodell at mcs.anl.gov
    Fri Sep  3 13:56:16 CDT 2010
Based on what you've sent us in the past, your mpiexec is actually running mcnp.mpi.  The error occurs during an MPI_Comm_dup somewhere in that code.  Running the test suite over the network will help us figure out whether there is a problem with your network.
-Dave
On Sep 3, 2010, at 1:50 PM CDT, SULLIVAN David (AREVA) wrote:
> That makes sense. Since my real problem is that mpiexec doesn't get to
> starting mcnp.mpi do we need the testing suite to troubleshoot or is
> there a source of clues elsewhere? I can get an NFS set up and all, but
> the testing suite isn't my true aim so if we don't need it...
> Dave
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
> Sent: Friday, September 03, 2010 2:47 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] cryptic (to me) error
> The general statement is true.  The problem is that "make testing" does
> not first build all executables and then second mpiexec each executable.
> Instead it builds each test  (on the machine where you invoked "make
> testing")  just before it is executed.  So the built executables only
> end up on the node where you ran "make testing".
> -Dave
> On Sep 3, 2010, at 1:43 PM CDT, SULLIVAN David (AREVA) wrote:
>> Interesting. So that would be the same for any executable that uses
>> mpiexec? This is confusing though because the install guide says that
>> it can be done either as NFS or a exact duplicate. I have set this up
>> before (as exact duplicates) without issues (with MPICH1 on WinXP) so
>> I assumed, as it states in the install guide, this has not changed.
>> Thanks again for the remedial assistance..
>> Dave
>> Sent: Friday, September 03, 2010 2:03 PM
>> The test suite directory must be on a shared filesystem because
>> mpiexec does not stage executables for you.
>> -Dave
