[mpich-discuss] mpich2 size of symbol 'cmpifcmb1_' changed, among others
Anthony Chan
chan at mcs.anl.gov
Mon Nov 29 13:27:56 CST 2010
Did you try to run your program ? The linker warning should be harmless
because mpich2 never access the individual elements of the common block
(but the address of the common symbol)
Another option is that you could try to recompile mpich2 with
--disable-multiple-aliases to see if the warning goes away. If you
do try this route, please let us know if the warning persists.
A.Chan
----- Original Message -----
> I have installed mpich2-1.3.1 from sources on my 64bit Linux
> workstation using GCC 4.1.2. My Fortran code uses -fdefault-integer-8
> to promote the Fortran integers, however this appears to be promoting
> the COMMON symbols in mpif.h. This causes the Warning: size of symbol
> 'mpifcmb1_' changed from 40 to 20 in libmpich.a (setbot.o).
> What can I do to fix this? Is there some other way besides recompiling
> mpich2 to use 8-byte integers? Thanks.
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
