[mpich-discuss] Question
Talla
jtalla at gmail.com
Wed Nov 24 01:38:23 CST 2010
Hello,
Thank you for answering my question, however, I am not a linux geek so
I am not sure how to do this? do you have any detailed information?
regards,
On Tue, Nov 23, 2010 at 7:56 PM, Darius Buntinas <buntinas at mcs.anl.gov> wrote:
> Try giving the full path to the executable. Also the executable must be accessible from each node using the same path (this is usually true if the executable is on a shared filesystem like NFS).
> -d
> On Nov 23, 2010, at 7:47 AM, Talla wrote:
>> Hello,
>> I really need your help, I am stuck with this issue for a while and I can not figure it out.
>> I build a cluster using rocks Centos 5.3 and every thing seems works fine accept when I am trying to submit a job to the cluster (try to do parallel simulation) I always get the message: mpiexec was unable to launch the specified application as it could not find an executable:
>> Executable: abinip"
>> I am using mpich2 in my system.
>> I am not sure what to do?
>> I am new to the linux world so any help will be appreciated.
>> Adam
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
