[mpich-discuss] Question
Darius Buntinas buntinas at mcs.anl.gov
Tue Nov 23 10:56:03 CST 2010
Try giving the full path to the executable.  Also the executable must be accessible from each node using the same path (this is usually true if the executable is on a shared filesystem like NFS).
-d
On Nov 23, 2010, at 7:47 AM, Talla wrote:
> Hello,
> I really need your help, I am stuck with this issue for a while and I can not figure it out.
> I build a cluster using rocks Centos 5.3 and every thing seems works fine accept when I am trying to submit a job to the cluster (try to do parallel simulation)  I always get the message: mpiexec was unable to launch the specified application as it could not find an executable:
> Executable: abinip"
> I am using mpich2 in my system.
> I am not sure what to do?
> I am new to the linux world so any help will be appreciated.
> Adam
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
