[mpich-discuss] Mixing different CPU architectures
Saurav Pathak
saurav at sas.upenn.edu
Thu Nov 18 04:31:44 CST 2010
Pavan,
Thank you for your reply. By ISA, do you mean the bus architecture? I
am not sure what it means. I shall be buying from the same vendor and
the same model, but different CPU choices.
This link compares the two CPUs.
http://ark.intel.com/Compare.aspx?ids=47922,37103,
I am not sure what I should be looking at to see if they are compatible
within MPICH2 restrictions.
Saurav
On 11/17/2010 11:57 AM, Pavan Balaji wrote:
> MPICH2 has a restriction on mixing different ISA's. Otherwise,
> different processor speeds, etc., should not matter much (apart from
> one of them being idle for longer during synchronization, as you
> pointed out). Of course, this is not a tested configuration, though.
> -- Pavan
> On 11/17/2010 10:49 AM, Saurav Pathak wrote:
>> Hi All,
>> This is not specifically a MPICH question, but related.
>> Is it OK to mix different CPU architectures in a set of nodes? For
>> instance, I have dual quad code (Intel E5530, 2.4 MHz, 8MB L3) system.
>> Can I add a dual six core (Intel X5650, 2.66MHz, 12M L3) node to the mix
>> and still use MPICH? Would I have to compile MPICH separately for
>> different architectures? For tasks that are equally divided, the faster
>> system will obviously be idle for longer.
>> I would like to hear your experience and comments.
>> Thanks,
>> Saurav
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
