[mpich-discuss] working mpi, now launch failure
Jayesh Krishna
jayesh at mcs.anl.gov
Wed Nov 17 14:15:01 CST 2010
Is that the only output message from mpiexec (Just a line "launch failed: FAIL" ?)?
Can you run a non-MPI program with mpiexec (mpiexec -n 2 hostname)? Can you run cpi.exe in the MPICH2 examples directory (mpiexec -n 2 "c:\Program Files\MPICH2\examples\cpi.exe")?
Jayesh
----- Original Message -----
To: Jayesh Krishna <jayesh at mcs.anl.gov>
Sent: Wed, 17 Nov 2010 14:11:28 -0600 (CST)
Subject: Re: [mpich-discuss] working mpi, now launch failure
Jayesh,
This is what I put in and I get the same error.
command:
> mpiexec -n 2 C:\Users\Emil\Documents\LAAMPS\lmp_win_mpi.exe -in in.graphene
error:
launch failed: FAIL
-Emil
Quoting Jayesh Krishna <jayesh at mcs.anl.gov>:
> Hi,
> Try providing the complete path to the executable (lmp_win_mpi.exe)
> and let us know if it works.
> If you still have problems copy-paste the command and the error
> message in your email.
> Regards,
> Jayesh
> From: Emil Sandoz-Rosado <ejs2166 at columbia.edu>
> To: mpich-discuss at mcs.anl.gov
> Sent: Tue, 16 Nov 2010 16:15:16 -0600 (CST)
> Subject: [mpich-discuss] working mpi, now launch failure
> Jayesh,
> I was able to get simulations running based on your suggestions. I shut the
> machine down and then rebooted to run new simulations. Now when I attempt
> to run mpiexec -n 2 lmp_win_mpi -in in.graphene, I get "launch failed: FAIL"
> Smpd -status indicates smpd is running fine on the machine.
> Any suggestions?
> -Emil
> mpich-discuss mailing list
