[mpich-discuss] seek help on mpi- mpich
Jayesh Krishna jayesh at mcs.anl.gov
Mon Nov 15 14:50:57 CST 2010
>> so, i am using the second administrator on both machine (they have the same passwd) to register...
 As I mentioned before try registering a username different from the "Administrator".
 Please follow the steps below,
1) On the XP machine & the Vista machine create a user, "mpiuser", with the same password (As I mentioned before do not register "Administrator" with mpiexec).
2) Register & Validate "mpiuser" on each machine.
3) Test whether the user, "mpiuser" can launch MPI processes locally on each machine.
4) Run your job across the XP & Vista machines and see if it works.
Jayesh
----- Original Message -----
To: Jayesh Krishna <jayesh at mcs.anl.gov>
Sent: Mon, 15 Nov 2010 14:43:00 -0600 (CST)
Subject: Re: seek help on mpi- mpich
Hello again,
Yeah,  At the first place I've done that (the same windows user/same
password with administrator privileges both on XP and Vista).
As I emailed to you,
  in XP, there are 2 windows user 1) hpxp (user with administrator
privileges)  2) Administrator (administrator privileges)
  in Vista, There are also 2 windows user 1) user (administrator
passwd) to register username/password with mpiexec which as follows:
> the error after >>mpiexec -validate  // done on XP
> Microsoft Windows XP [Version 5.1.2600]
> (C) Copyright 1985-2001 Microsoft Corp.
> C:\Documents and Settings\Administrator>mpiexec -remove
> Account and password removed from the Registry.
> C:\Documents and Settings\Administrator>mpiexec -register
> account (domain\user) [HPXP\Administrator]: Administrator
> password: **
> confirm password: **
> Password encrypted into the Registry.
> C:\Documents and Settings\Administrator>mpiexec -validate
> Error during CryptEncrypt: Unknown failure 234
> unable to encrypt the password for the validate command.
> the error after >>mpiexec -validate Administrator/** //done on Vista
> Microsoft Windows XP [Version 6.0.6002]
> Copyright (C) 2006 Microsoft Corp. All right reserved.
> C:\Users\Administrator>mpiexec -remove
> C:\Users\Administrator>mpiexec -register
> password:
> confirm password:
> C:\Users\Administrator>mpiexec -validate
Eventhough I cannot validate, but I can run the MPI program from 1 node or
multithreading.
result :
C:\Documents and Settings\Administrator\My Documents\myPar>mpiexec
-machinefile mf.txt helloCluster.exe
> >> Master process rank#0 sending message ~Hello, world
in both machine.
The firewalls are all off.
Currently, I tried to change the administrator privileges on user hpxp on
XP, but it disables me to change the role to user privilege, so that I only
have 1 administrator privileges. in vista, it can be done easily, will let
you know later.
before that,  do you have any suggestions please?
thanks Mr Jayesh.
On Mon, Nov 15, 2010 at 11:20 PM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
>  Is "myuser" a valid Windows user ? You need to register an existing
> Windows username/password with mpiexec.
>  Please create a windows user (The same username/password on XP & Vista
> machines) with administrator privileges and try registering that
> username/password with mpiexec. Let us know the results.
> Regards,
> Jayesh
> From: UmmuRifqi <ummurifqi09 at gmail.com>
> Sent: Sun, 14 Nov 2010 20:41:00 -0600 (CST)
> Hello again Mr Jayesh.
> I've removed and created new account other than Administrator as below (
> myuser), (by mpiexec -register)
> then it resulted the same one, I can register but could'nt validate them.
> FYI, in my XP machine, there are 2 accounts of administrator role..1)
> Administrator 2) hpxp  (we can see it on window welcome screen)
> also in my vista machine, there are also 2 accounts of administrator.
> I installed the mPICH2  'everyone' not 'just me' features.
> the output on my XP machine:
> -register
> account (domain\user) [HPXP\Administrator]: myuser
> password:
> confirm password:
> -validate
> help me please. Thanks.
> On Thu, Nov 11, 2010 at 10:49 PM, Jayesh Krishna <jayesh at mcs.anl.gov>
> wrote:
> > Hi,
> >  Can you try registering/validating a username (an admin user) other than
> > "Administrator" ?
> > Regards,
> > Jayesh
> > Sent: Wed, 10 Nov 2010 22:25:46 -0600 (CST)
> > Hello again,
> > step 1-2 done successfully.
> > step 3 unsuccessful because when to validate the username/password, there
> > is
> > an error..it hang and never return the command prompt until I press
> ctrl-C
> > after several minutes waiting.
> > password:
> > confirm password:
> > password:
> > confirm password:
> > how it can be solved , attached is my smpd.log
> > thanks Mr. Jayesh.
> > On Thu, Nov 11, 2010 at 9:20 AM, UmmuRifqi <ummurifqi09 at gmail.com>
> wrote:
> > > Thanks for the feedback & suggestion.
> > > Just arrived the lab, I'll try it out and will let you know the result.
> > > On Wed, Nov 10, 2010 at 11:15 PM, Jayesh Krishna <jayesh at mcs.anl.gov
> > >wrote:
> > >> Hi,
> > >>  Please try the following,
> > >> 1) Create a machinefile, mf.txt, with the following contents,
> > >> # XP node
> > >> 192.168.33.69:1
> > >> # Vista node
> > >> 192.168.33.68:1
> > >> 2) Make sure helloCluster.exe is available in C:\temp on both the
> > >> machines.
> > >> 3) Remove any usernames registered on the machines using the "-remove"
> > >> option of mpiexec ("mpiexec -remove" on both the machines) and
> > re-register a
> > >> username/password available on both the machines (same user - with the
> > same
> > >> password - should be available on both the machines) using the
> > "-register"
> > >> option of mpiexec ("mpiexec -register" on both the machines).
> > >>   Validate the username/password registered using the "-validate"
> option
> > >> of mpiexec ("mpiexec -validate" on both the machines).
> > >> 4) Try running helloCluster.exe on both machines (XP & Vista) locally
> > >> (mpiexec -n 2 helloCluster.exe)
> > >> 5) Try running a non-MPI program like hostname on both the machines
> > >> (mpiexec -n 2 -machinefile mf.txt hostname)
> > >> 6) Now try running helloCluster.exe on the cluster (mpiexec -n 2
> > >> -machinefile mf.txt c:\temp\helloCluster.exe)
> > >> (PS: If you get an error message please copy-paste it in your email)
> > >> Regards,
> > >> Jayesh
> > >> To: jayesh at mcs.anl.gov
> > >> Sent: Wed, 10 Nov 2010 02:43:14 -0600 (CST)
> > >> Subject: seek help on mpi- mpich
> > >> Hello,
> > >> I am new to mpich/mpi and I learn this by myself from the Internet to
> do
> > >> my
> > >> research.
> > >> I've review the discussion mpich-discuss (
> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-July/007469.html)
> > >> been following the thread after thread and decided to email you if you
> > >> could
> > >> help me on windows clustering using mpich2.
> > >> I'm doing on XP and Vista machine, 32 bit, mpich2 version
> > >> mpich2-1.2.1p1-win-ia32, it works on hello world program  for single
> > node
> > >> (stand alone), but it does not run on multinode ( the nest machine).
> it
> > >> says
> > >> -machinefile mf.pg helloCluster.exe
> > >> the firewall already off. the machine file contains
> > >> 192.168.33.69 0 /Documents and Settings/Administrator/My
> > Documents/myPar/
> > >> this is XP machine
> > >> 192.168.33.68 1
> > >> /Users/Administrator/Documents/myPar/
> > >> #this
> > >> is Vista machine
> > >> please help me. what else considering i have to take to enable the
> > >> interaction between the nodes because after this i need to do it on
> 3,5,
> > 8
> > >> machines.
> > >> thank you.
