[mpich-discuss] seek help on mpi- mpich
Jayesh Krishna
jayesh at mcs.anl.gov
Mon Nov 15 09:20:15 CST 2010
Is "myuser" a valid Windows user ? You need to register an existing Windows username/password with mpiexec.
Please create a windows user (The same username/password on XP & Vista machines) with administrator privileges and try registering that username/password with mpiexec. Let us know the results.
Jayesh
----- Original Message -----
To: Jayesh Krishna <jayesh at mcs.anl.gov>
Sent: Sun, 14 Nov 2010 20:41:00 -0600 (CST)
Subject: Re: seek help on mpi- mpich
Hello again Mr Jayesh.
I've removed and created new account other than Administrator as below (
myuser), (by mpiexec -register)
then it resulted the same one, I can register but could'nt validate them.
FYI, in my XP machine, there are 2 accounts of administrator role..1)
Administrator 2) hpxp (we can see it on window welcome screen)
also in my vista machine, there are also 2 accounts of administrator.
I installed the mPICH2 'everyone' not 'just me' features.
the output on my XP machine:
C:\Documents and Settings\Administrator\My Documents\myPar>mpiexec -register
account (domain\user) [HPXP\Administrator]: myuser
password:
confirm password:
Password encrypted into the Registry.
C:\Documents and Settings\Administrator\My Documents\myPar>mpiexec -validate
Error during CryptEncrypt: Unknown failure 234
unable to encrypt the password for the validate command.
help me please. Thanks.
On Thu, Nov 11, 2010 at 10:49 PM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
> Can you try registering/validating a username (an admin user) other than
> "Administrator" ?
> Regards,
> Jayesh
> From: UmmuRifqi <ummurifqi09 at gmail.com>
> Sent: Wed, 10 Nov 2010 22:25:46 -0600 (CST)
> Hello again,
> step 1-2 done successfully.
> step 3 unsuccessful because when to validate the username/password, there
> is
> an error..it hang and never return the command prompt until I press ctrl-C
> after several minutes waiting.
> the error after >>mpiexec -validate // done on XP
> Microsoft Windows XP [Version 5.1.2600]
> (C) Copyright 1985-2001 Microsoft Corp.
> C:\Documents and Settings\Administrator>mpiexec -remove
> Account and password removed from the Registry.
> C:\Documents and Settings\Administrator>mpiexec -register
> account (domain\user) [HPXP\Administrator]: Administrator
> password:
> confirm password:
> C:\Documents and Settings\Administrator>mpiexec -validate
> the error after >>mpiexec -validate Administrator/** //done on Vista
> Microsoft Windows XP [Version 6.0.6002]
> Copyright (C) 2006 Microsoft Corp. All right reserved.
> C:\Users\Administrator>mpiexec -remove
> C:\Users\Administrator>mpiexec -register
> password:
> confirm password:
> C:\Users\Administrator>mpiexec -validate
> how it can be solved , attached is my smpd.log
> thanks Mr. Jayesh.
> On Thu, Nov 11, 2010 at 9:20 AM, UmmuRifqi <ummurifqi09 at gmail.com> wrote:
> > Thanks for the feedback & suggestion.
> > Just arrived the lab, I'll try it out and will let you know the result.
> > On Wed, Nov 10, 2010 at 11:15 PM, Jayesh Krishna <jayesh at mcs.anl.gov
> >wrote:
> >> Hi,
> >> Please try the following,
> >> 1) Create a machinefile, mf.txt, with the following contents,
> >> # XP node
> >> 192.168.33.69:1
> >> # Vista node
> >> 192.168.33.68:1
> >> 2) Make sure helloCluster.exe is available in C:\temp on both the
> >> machines.
> >> 3) Remove any usernames registered on the machines using the "-remove"
> >> option of mpiexec ("mpiexec -remove" on both the machines) and
> re-register a
> >> username/password available on both the machines (same user - with the
> same
> >> password - should be available on both the machines) using the
> "-register"
> >> option of mpiexec ("mpiexec -register" on both the machines).
> >> Validate the username/password registered using the "-validate" option
> >> of mpiexec ("mpiexec -validate" on both the machines).
> >> 4) Try running helloCluster.exe on both machines (XP & Vista) locally
> >> (mpiexec -n 2 helloCluster.exe)
> >> 5) Try running a non-MPI program like hostname on both the machines
> >> (mpiexec -n 2 -machinefile mf.txt hostname)
> >> 6) Now try running helloCluster.exe on the cluster (mpiexec -n 2
> >> -machinefile mf.txt c:\temp\helloCluster.exe)
> >> (PS: If you get an error message please copy-paste it in your email)
> >> Regards,
> >> Jayesh
> >> To: jayesh at mcs.anl.gov
> >> Sent: Wed, 10 Nov 2010 02:43:14 -0600 (CST)
> >> Subject: seek help on mpi- mpich
> >> Hello,
> >> I am new to mpich/mpi and I learn this by myself from the Internet to do
> >> my
> >> research.
> >> I've review the discussion mpich-discuss (
> >> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-July/007469.html)
> >> been following the thread after thread and decided to email you if you
> >> could
> >> help me on windows clustering using mpich2.
> >> I'm doing on XP and Vista machine, 32 bit, mpich2 version
> >> mpich2-1.2.1p1-win-ia32, it works on hello world program for single
> node
> >> (stand alone), but it does not run on multinode ( the nest machine). it
> >> says
> >> -machinefile mf.pg helloCluster.exe
> >> Master process rank#0 sending message ~Hello, world
> >> the firewall already off. the machine file contains
> >> 192.168.33.69 0 /Documents and Settings/Administrator/My
> Documents/myPar/
> >> this is XP machine
> >> 192.168.33.68 1
> >> /Users/Administrator/Documents/myPar/
> >> #this
> >> is Vista machine
> >> please help me. what else considering i have to take to enable the
> >> interaction between the nodes because after this i need to do it on 3,5,
> 8
> >> machines.
> >> thank you.
