[mpich-discuss] cygwin & mingw64 & windows 7 (64bits)
Jean-Michel Beuken jean-michel.beuken at uclouvain.be
Mon Nov 8 15:55:12 CST 2010
On 08/11/2010 22:32, Jayesh Krishna wrote:
> Hi,
>   From the error code it looks like access violation. Can you try running the executable from a mingw bash prompt ?
mingw bash prompt ?
same as in cygwin ?
in cygwin, I run a bash ("Run as administrator") and start
$ ./pi3f90.exe
$ echo $?
127
jmb
>   I will also try installing mingw 64-bit at the lab and let you know the results.
> Regards,
> Jayesh
> From: Jean-Michel Beuken<jean-michel.beuken at uclouvain.be>
> To: mpich-discuss at mcs.anl.gov
> Sent: Mon, 08 Nov 2010 15:19:48 -0600 (CST)
> Subject: Re: [mpich-discuss] cygwin&  mingw64&  windows 7 (64bits)
> Hi,
>>>> $ ls /cygdrive/c/lib/ ...
>>    Did you install MPICH2 in "C:\" ? Why did you change the default installation path (Why didn't you change it so that the directory is something different from "c:\" - eg: "c:\MPICH2")?
>>    Did you get any errors during the MPICH2 install process (using the windows installers)?
> no.. it's my fault...
>>>> Fatal Error: File 'mpi.mod' opened at (1) is not a GFORTRAN module file
>>    The fortran module file provided with MPICH2 on Windows (binaries installed using windows installer) is only compatible with Intel Fortran Compiler for Windows.
> ok...
>>>> in bash, I start smpd ...
>>    If you install MPICH2 on Windows using the windows installers you shouldn't have to start SMPD manually. The windows installers install SMPD as a service when you install MPICH2.
> ha yes, now you say , I remember...
>>    Try running the executable at the command prompt without mpiexec (Type "pi3f90" at the command prompt). This should show a better error message (If you are missing any dependencies etc).
> I start on "Command Prompt"  pi3f90.exe but
> there is a popup says : "pif90.exe has stopped working : Windows is checking for a solution to the problem" :-\
> nothing on stdout
> thanks
> regards
> jmb
>> Regards,
>> Jayesh
>> Sent: Mon, 08 Nov 2010 14:46:45 -0600 (CST)
>> Hello Jayesh,
>> thank you for ypur quick answer...
>>>     Mingw does not provide the POSIX runtime environment that Nemesis/sock needs. Try compiling your code with gcc (from mingw package) and MPICH2 (64-bit) installed using the windows installers (mpich2-1.3-win-x86-64.msi).
>> I had installed this package but I'm not a windows specialist
>> customarily, on linux, the compilation of mpich2 produces some wrappers ( like mpif90 ) and the link is made easily...
>> after installation of the msi package under Windows , there are :
>> TraceInput.lib    cxx.lib  fmpich2.lib  fmpich2g.lib  irlog2rlog.lib  mpe.lib  mpi.lib  rlog.lib
>> $ ls /cygdrive/c/include/
>> clog_commset.h    clog_inttypes.h  mpe.h        mpe_logf.h    mpi.h     mpi_base.mod        mpi_sizeofs.mod  mpif.h
>> clog_const.h    clog_uuid.h     mpe_log.h  mpe_misc.h    mpi.mod  mpi_constants.mod  mpicxx.h         mpio.h
>> tried with the f90 example found in mpich2 : pi3f90.f90
>> under linux :
>> [root at shiva f90]# mpif90 -show
>> gfortran -I/usr/local/mpich2_gcc45/include -L/usr/local/mpich2_gcc45/lib -lmpichf90 -lmpich -lopa -lmpl -lrt -lpthread
>> [root at shiva f90]# echo $LD_LIBRARY_PATH
>> /usr/local/gcc45/lib64:/usr/local/gcc45/lib:/usr/local/lib:/usr/local/lib64:/usr/local/mpich2_gcc45/lib
>> [root at shiva f90]# make
>> ../../bin/mpif90  -c pi3f90.f90
>> ../../bin/mpif90   -o pi3f90 pi3f90.o -lrt -lpthread
>> under cygwin  with the MINGW :
>> $ x86_64-w64-mingw32-gfortran.exe -I/cygdrive/c/include/ -c pi3f90.f90
>> pi3f90.f90:25.8:
>>     use mpi
>>            1
>> then, I comment the 'use mpi' and add
>> include 'mpif.h'   in pi3f90.f90
>> $ x86_64-w64-mingw32-gfortran.exe -I/cygdrive/c/include/ -c pi3f90.f90  -fno-range-check  -fsecond-underscore
>> $ x86_64-w64-mingw32-gfortran.exe  -o pi3f90 pi3f90.o -L/cygdrive/c/lib -lfmpich2 -lfmpich2g -lmpi -static-libgcc -static-libgfortran
>> I must put "-fno-range-check" because error :
>> mpif.h:340.42:
>>        Included at pi3f90.f90:26:
>>           PARAMETER (MPI_FLOAT_INT=2348810240)
>>                                              1
>> Error: Integer too big for its kind at (1). This check can be disabled with the option -fno-range-check
>> in bash, I start smpd ( I verify then the service runs )  and start :
>> /cygdrive/c/bin/mpiexec.exe -n 4 pi3f90
>> but nothing :-(
>> with wmpiconfig, I see the exitcode  for the 4 processes = -1073741819
>> the  mpich2-1.3-win-x86-64.msi  has been compiled  with which compilers ?
>> regards
>> jmb
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
