[mpich-discuss] cygwin & mingw64 & windows 7 (64bits)
Jayesh Krishna
jayesh at mcs.anl.gov
Mon Nov 8 15:32:16 CST 2010
From the error code it looks like access violation. Can you try running the executable from a mingw bash prompt ?
I will also try installing mingw 64-bit at the lab and let you know the results.
Jayesh
----- Original Message -----
From: Jean-Michel Beuken <jean-michel.beuken at uclouvain.be>
Sent: Mon, 08 Nov 2010 15:19:48 -0600 (CST)
Subject: Re: [mpich-discuss] cygwin & mingw64 & windows 7 (64bits)
>>> $ ls /cygdrive/c/lib/ ...
> Did you install MPICH2 in "C:\" ? Why did you change the default installation path (Why didn't you change it so that the directory is something different from "c:\" - eg: "c:\MPICH2")?
> Did you get any errors during the MPICH2 install process (using the windows installers)?
no.. it's my fault...
>>> Fatal Error: File 'mpi.mod' opened at (1) is not a GFORTRAN module file
> The fortran module file provided with MPICH2 on Windows (binaries installed using windows installer) is only compatible with Intel Fortran Compiler for Windows.
ok...
>>> in bash, I start smpd ...
> If you install MPICH2 on Windows using the windows installers you shouldn't have to start SMPD manually. The windows installers install SMPD as a service when you install MPICH2.
ha yes, now you say , I remember...
> Try running the executable at the command prompt without mpiexec (Type "pi3f90" at the command prompt). This should show a better error message (If you are missing any dependencies etc).
I start on "Command Prompt" pi3f90.exe but
there is a popup says : "pif90.exe has stopped working : Windows is checking for a solution to the problem" :-\
nothing on stdout
thanks
regards
jmb
> Regards,
> Jayesh
> From: Jean-Michel Beuken<jean-michel.beuken at uclouvain.be>
> Sent: Mon, 08 Nov 2010 14:46:45 -0600 (CST)
> Subject: Re: [mpich-discuss] cygwin& mingw64& windows 7 (64bits)
> Hello Jayesh,
> thank you for ypur quick answer...
>> Mingw does not provide the POSIX runtime environment that Nemesis/sock needs. Try compiling your code with gcc (from mingw package) and MPICH2 (64-bit) installed using the windows installers (mpich2-1.3-win-x86-64.msi).
> I had installed this package but I'm not a windows specialist
> customarily, on linux, the compilation of mpich2 produces some wrappers ( like mpif90 ) and the link is made easily...
> after installation of the msi package under Windows , there are :
> TraceInput.lib cxx.lib fmpich2.lib fmpich2g.lib irlog2rlog.lib mpe.lib mpi.lib rlog.lib
> $ ls /cygdrive/c/include/
> clog_commset.h clog_inttypes.h mpe.h mpe_logf.h mpi.h mpi_base.mod mpi_sizeofs.mod mpif.h
> clog_const.h clog_uuid.h mpe_log.h mpe_misc.h mpi.mod mpi_constants.mod mpicxx.h mpio.h
> tried with the f90 example found in mpich2 : pi3f90.f90
> under linux :
> [root at shiva f90]# mpif90 -show
> gfortran -I/usr/local/mpich2_gcc45/include -L/usr/local/mpich2_gcc45/lib -lmpichf90 -lmpich -lopa -lmpl -lrt -lpthread
> [root at shiva f90]# echo $LD_LIBRARY_PATH
> /usr/local/gcc45/lib64:/usr/local/gcc45/lib:/usr/local/lib:/usr/local/lib64:/usr/local/mpich2_gcc45/lib
> [root at shiva f90]# make
> ../../bin/mpif90 -c pi3f90.f90
> ../../bin/mpif90 -o pi3f90 pi3f90.o -lrt -lpthread
> under cygwin with the MINGW :
> $ x86_64-w64-mingw32-gfortran.exe -I/cygdrive/c/include/ -c pi3f90.f90
> pi3f90.f90:25.8:
> use mpi
> 1
> then, I comment the 'use mpi' and add
> include 'mpif.h' in pi3f90.f90
> $ x86_64-w64-mingw32-gfortran.exe -I/cygdrive/c/include/ -c pi3f90.f90 -fno-range-check -fsecond-underscore
> $ x86_64-w64-mingw32-gfortran.exe -o pi3f90 pi3f90.o -L/cygdrive/c/lib -lfmpich2 -lfmpich2g -lmpi -static-libgcc -static-libgfortran
> I must put "-fno-range-check" because error :
> mpif.h:340.42:
> Included at pi3f90.f90:26:
> PARAMETER (MPI_FLOAT_INT=2348810240)
> 1
> Error: Integer too big for its kind at (1). This check can be disabled with the option -fno-range-check
> in bash, I start smpd ( I verify then the service runs ) and start :
> /cygdrive/c/bin/mpiexec.exe -n 4 pi3f90
> but nothing :-(
> with wmpiconfig, I see the exitcode for the 4 processes = -1073741819
> the mpich2-1.3-win-x86-64.msi has been compiled with which compilers ?
> regards
> jmb
> mpich-discuss mailing list
