[mpich-discuss] How to handle complex variables
Jayesh Krishna
jayesh at mcs.anl.gov
Mon Nov 8 09:30:32 CST 2010
You should be using "DOUBLE COMPLEX" fortran type (not COMPLEX) for MPI_DOUBLE_COMPLEX types. Let us know if it works.
Jayesh
----- Original Message -----
Sent: Mon, 08 Nov 2010 09:24:59 -0600 (CST)
Subject: Re: [mpich-discuss] How to handle complex variables
Are you using MPICH2 on windows or unix ? Which version of MPICH2 are you using ?
Are you getting an error message when you run your code (What is the error message)? I am not a fortran expert but shouldn't you be using complex(16) (instead of complex(8)) for MPI_DOUBLE_COMPLEX ?
Jayesh
Sent: Mon, 08 Nov 2010 08:57:54 -0600 (CST)
Subject: [mpich-discuss] How to handle complex variables
Hi everyone,
I've been using Fortran90 + MPICH2 for a while and I'm trying now to
broadcast complex variables amongst the processes. I've just learned
about the MPI_DOUBLE_COMPLEX datatype, but I'm not able to use it
properly... Here is the simple test program I've been using:
program MPI_cmplx
use MPI
implicit none
integer :: MPI_ID, MPI_size, MPI_err
complex(8) :: z1, z2
! Initialize
call MPI_INIT(MPI_err)
call MPI_COMM_RANK(MPI_COMM_WORLD,MPI_ID,MPI_err)
call MPI_COMM_SIZE(MPI_COMM_WORLD,MPI_size,MPI_err)
! Broadcast
THIS WORKS
z1 = (0.0d0,0.0d0)
if(MPI_ID == 0) then
z1 = (1.5d0,0.5d0)
write(*,*) "BCAST with count=1*MPI_DOUBLE_COMPLEX:", z1
endif
call MPI_BCAST(z1,1,MPI_DOUBLE_COMPLEX,0,MPI_COMM_WORLD,MPI_err)
call MPI_BARRIER(MPI_COMM_WORLD,MPI_err)
if(MPI_ID /= 0) then
write(*,*) "Proc.", MPI_ID, " received", z1
endif
! Reduce
<<< THIS DOESN'T WORK
write(*,*)
write(*,*) "REDUCE with count=1*MPI_DOUBLE_COMPLEX"
endif
z1 = (1.5d0,0.5d0)
z1 = z1 + cmplx(MPI_ID,MPI_ID)
z2 = (0.0d0,0.0d0)
write(*,*) "Proc.", MPI_ID, " has", z1
call MPI_REDUCE(z1,z2,1,MPI_DOUBLE_COMPLEX,MPI_SUM,0,MPI_COMM_WORLD)
write(*,*) "Sum is", z2
endif
! End
call MPI_FINALIZE(MPI_err)
end program MPI_cmplx
Could anyone help me on this please?
Thanks in advance,
Antonin
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
mpich-discuss mailing list
