[mpich-discuss] How to handle complex variables
Jayesh Krishna
jayesh at mcs.anl.gov
Mon Nov 8 09:24:59 CST 2010
Are you using MPICH2 on windows or unix ? Which version of MPICH2 are you using ?
Are you getting an error message when you run your code (What is the error message)? I am not a fortran expert but shouldn't you be using complex(16) (instead of complex(8)) for MPI_DOUBLE_COMPLEX ?
Jayesh
----- Original Message -----
Sent: Mon, 08 Nov 2010 08:57:54 -0600 (CST)
Subject: [mpich-discuss] How to handle complex variables
Hi everyone,
I've been using Fortran90 + MPICH2 for a while and I'm trying now to
broadcast complex variables amongst the processes. I've just learned
about the MPI_DOUBLE_COMPLEX datatype, but I'm not able to use it
properly... Here is the simple test program I've been using:
program MPI_cmplx
use MPI
implicit none
integer :: MPI_ID, MPI_size, MPI_err
complex(8) :: z1, z2
! Initialize
call MPI_INIT(MPI_err)
call MPI_COMM_RANK(MPI_COMM_WORLD,MPI_ID,MPI_err)
call MPI_COMM_SIZE(MPI_COMM_WORLD,MPI_size,MPI_err)
! Broadcast
THIS WORKS
z1 = (0.0d0,0.0d0)
if(MPI_ID == 0) then
z1 = (1.5d0,0.5d0)
write(*,*) "BCAST with count=1*MPI_DOUBLE_COMPLEX:", z1
endif
call MPI_BCAST(z1,1,MPI_DOUBLE_COMPLEX,0,MPI_COMM_WORLD,MPI_err)
call MPI_BARRIER(MPI_COMM_WORLD,MPI_err)
if(MPI_ID /= 0) then
write(*,*) "Proc.", MPI_ID, " received", z1
endif
! Reduce
<<< THIS DOESN'T WORK
write(*,*)
write(*,*) "REDUCE with count=1*MPI_DOUBLE_COMPLEX"
endif
z1 = (1.5d0,0.5d0)
z1 = z1 + cmplx(MPI_ID,MPI_ID)
z2 = (0.0d0,0.0d0)
write(*,*) "Proc.", MPI_ID, " has", z1
call MPI_REDUCE(z1,z2,1,MPI_DOUBLE_COMPLEX,MPI_SUM,0,MPI_COMM_WORLD)
write(*,*) "Sum is", z2
endif
! End
call MPI_FINALIZE(MPI_err)
end program MPI_cmplx
Could anyone help me on this please?
Thanks in advance,
Antonin
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
