[mpich-discuss] g95 and mpich2 on new i686 MacOS 10.6 machine
Pavan Balaji balaji at mcs.anl.gov
Fri May 28 09:01:37 CDT 2010
Robert,
You'll need compatible compilers for all language bindings you configure
MPICH2 with. In this case, you can either try to get a 64-bit Fortran
compiler and pass it to MPICH2's configure using:
% ./configure F77=<64-bit_compiler> F90=<64-bit_compiler>
... or you can disable fortran, if you don't plan to use it:
% ./configure --disable-f77 --disable-f90
  -- Pavan
On 05/28/2010 03:49 AM, Robert Kerr wrote:
> I am working to install Fortran 90 and mpich2 on my new
> Apple MacBook Pro with an Intel Core 2 Duo processor running
> MacOS 10.6 machine.  I am moving from the Suse-Linux world.
> I have downloaded and installed the Xcode package from
> Apple Developer Tools.
> I have downloaded and installed the 10.6 version of fink.
> I have gone to the website http://www.g95.org/
> and downloaded the x86 OSX version.  The
> executable worked immediately after I untarred it.
>>From the error message from mpich2, this might not
> be the version of Fortran 90 that will work with mpich2.
> The question now is what mpich2 to download and
> any modifications to make it work.
> I have downloaded: mpich2-1.2.1p1
> I run ./configure
> ERROR: in c.txt at the end I get:configure: error: ****  Incompatible
> Fortran and C Object File Types!  ****
> F77 Object File Type produced by "gfortran  -O2" is : : Mach-O object i386.
>  C  Object File Type produced by "gcc  -O2" is : : Mach-O 64-bit object
> x86-64
>>From what I can tell this is saying the fortran I got is for the i386
> processor, which I assume is the old 32-bit processor, even though it
> runs on my machine, which I assume is 64-bit.  But mpich2 needs a
> C-compiler and the version I got through Xcode supplies a 64-bit version.
> At what stage in this process have I made a mistake?
> To get a reply do I need to login somewhere or is it sent to me?
> Robert Kerr
> Robert M. Kerr     email: Robert.Kerr at warwick.ac.uk
> School of Engineering
> University of Warwick
> Coventry CV4 7AL, United Kingdom
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
