[mpich-discuss] try to install MPICH2 on SGI under local account
Rajeev Thakur thakur at mcs.anl.gov
Thu May 27 11:32:17 CDT 2010
When you login to the SGI machine, you can cd to a directory that is
local to that machine, say /tmp or ask the administrator which is the
directory corresponding to a local disk. You can build MPICH2 there. You
can specify an install directory that is on NFS via the --prefix option.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Mei, Rui
> Sent: Thursday, May 27, 2010 9:00 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] try to install MPICH2 on SGI
> under local account
> In regards to the 3rd point,  The building directory
> MPICH2-1.3a2 and the installation directory mpi are both
> under /u/home/rum06003/ on the SGI server. So they should
> bear the same time clock. I am not sure if I have understand
> your point
> clearly.  That SGI server is not mounted on my local machine,
> I usually ssh to that machine. So I do not know how to build it from
> my local machine /tmp and set the prefix to be
> /u/home/rum06003/mpi on that SGI machine.
> Thank you for any suggestion or clarification.
> Rui
> [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Pavan Balaji
> [balaji at mcs.anl.gov]
> Sent: Wednesday, May 26, 2010 11:06 PM
> under local account
> Aha. It looks like a timestamp issue. Your "make" is causing
> simplemake
> to be re-executed, which should never happen unless the
> timestamp of the
> Makefile.in is more recent than the Makefile.
> There are a bunch of problems that need to be fixed here:
> 1. When the time stamps don't match for released versions, we should
> just throw an error during make, instead of leading to such
> cryptic bugs.
> 2. You should not have to give the --with-atomic-primitives=no option
> when using --with-device=ch3:sock.
> 3. For some reason you are getting incorrect time stamps for
> your files.
> (1) and (2) are a problem with MPICH2, which I'll fix. (3) is
> a problem
> with your setup. Are your files on an NFS server, or some other shared
> file system? Can you make sure the time stamp on your login node (or
> which ever node you are building MPICH2 on) is the same as your file
> server? Alternatively, you can try building on a local
> file-system such
> as /tmp. Your prefix can still be /u/home/rum06003/mpi.
>   -- Pavan
> On 05/26/2010 09:53 PM, Mei, Rui wrote:
> > I first tried ./configure --prefix=/u/home/rum06003/mpi
> --with-device=ch3:sock 2>&1 | tee c1.txt and it gave me error
> (see c1.txt)
> > and suggest to use --with-atomic-primitives=no option.
> > So I then tried ./configure --prefix=/u/home/rum06003/mpi
> --with-atomic-primitives=no 2>&1 | tee c.txt (it's ok, see c.txt)
> > Then I executed: make 2>&1 | tee m.txt (it gave error, see m.txt)
> > At last I executed: make install 2>&1 | tee mi.txt (it also
> gave error, see mi.txt)
> > And there is indeed a difference between Makefile.in an
> dMakefile.in.original.
> > Thank you for any suggestion.
> > Rui
> > Sent: Wednesday, May 26, 2010 9:26 PM
> under local account
> > On 05/26/2010 08:20 PM, Pavan Balaji wrote:
> >> 3. Run configure using:
> >> % ./configure --prefix=/u/home/rum06003/mpi
> >> | tee c.txt
> > Small correction here. I'll need you to run both configure and make:
> > | tee c.txt
> > % make
> > ... then send me both Makefile.in and Makefile.in.original
> > Thanks,
> >   -- Pavan
> > Pavan Balaji
> > http://www.mcs.anl.gov/~balaji
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Pavan Balaji
