[mpich-discuss] try to install MPICH2 on SGI under local account
Mei, Rui
rum06003 at engr.uconn.edu
Wed May 26 21:53:17 CDT 2010
I first tried ./configure --prefix=/u/home/rum06003/mpi --with-device=ch3:sock 2>&1 | tee c1.txt and it gave me error (see c1.txt)
and suggest to use --with-atomic-primitives=no option.
So I then tried ./configure --prefix=/u/home/rum06003/mpi --with-atomic-primitives=no 2>&1 | tee c.txt (it's ok, see c.txt)
Then I executed: make 2>&1 | tee m.txt (it gave error, see m.txt)
At last I executed: make install 2>&1 | tee mi.txt (it also gave error, see mi.txt)
And there is indeed a difference between Makefile.in an dMakefile.in.original.
Thank you for any suggestion.
Rui
From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Pavan Balaji [balaji at mcs.anl.gov]
Sent: Wednesday, May 26, 2010 9:26 PM
Subject: Re: [mpich-discuss] try to install MPICH2 on SGI under local account
On 05/26/2010 08:20 PM, Pavan Balaji wrote:
> 3. Run configure using:
> % ./configure --prefix=/u/home/rum06003/mpi --with-device=ch3:sock 2>&1
> | tee c.txt
Small correction here. I'll need you to run both configure and make:
| tee c.txt
% make
... then send me both Makefile.in and Makefile.in.original
-- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
mpich-discuss mailing list
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100526/6412ee8d/attachment-0004.txt>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100526/6412ee8d/attachment-0005.txt>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100526/6412ee8d/attachment-0006.txt>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100526/6412ee8d/attachment-0007.txt>
Desc: Makefile.in
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100526/6412ee8d/attachment-0003.obj>
Desc: Makefile.in.original
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100526/6412ee8d/attachment-0004.obj>
Desc: Makefile
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100526/6412ee8d/attachment-0005.obj>
