[mpich-discuss] [mpich2-dev] I can not make MPI recognizes a dual core
Jayesh Krishna
jayesh at mcs.anl.gov
Wed May 26 10:00:05 CDT 2010
Is the new user, MPI, an admin user ? How did you install MPICH2 for only that user ? I am still surprised that you have to install smpd explicitly (that the installer does not install it for you).
MPICH2 runtime system requires user credentials to launch an MPI job. Looks like you are logged on as "User-PC\MPI". Try entering the password (for user "User-PC\MPI") without entering the username (When mpiexec prompts for the username just press the enter key).
I would also recommend getting help from your sysadmin regarding installation of MPICH2 (Or better anyone else in your team who has installed/used MPICH2).
Jayesh
----- Original Message -----
From: "Yessica Brinkmann" <yessica.brinkmann at gmail.com>
To: jayesh at mcs.anl.gov
Cc: mpich-discuss at mcs.anl.gov
Sent: Tuesday, May 25, 2010 9:14:53 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich2-dev] I can not make MPI recognizes a dual core
Hi, very thanks for your response.
I created a new user called MPI and I reinstalled the MPICH2 only for
this user, and I executed the sentences that you say for me.
When I write
smpd -uninstall
The system response to me:
Stopping MPICH2 Process Manager, Argonne National Lab.
MPICH2 Process Manager, Argonne National Lab stopped.
MPICH2 Process Manager, Argonne National Lab removed.
When I write:
smpd -install -phrase behappy
MPICH2 Process Manager, Argonne National Lab installed.
When I write:
smpd -status
smpd running on User-PC
When I write:
mpiexec -n 2 hostname
User credentials needed to launch processes:
account(domain\user) [User-PC\MPI]:
And at this point I does not how I should write, I try with MPI or
User-PC\MPI, but does not work.
Then the system ask to me for the password:
I write the password that I use for the MPI user, and the system response to me:
Credentials for MPI rejected connecting to User-PC.
Aborting: Unable to connect to User-PC
I think this is because I does not known how I should write when the
system ask to me:
I will thanks any help.
Yessica Brinkmann
2010/5/25 <jayesh at mcs.anl.gov>:
> Hi,
> This is strange... With the information provided by you I can only make the following suggestions (I can provide better suggestions if you provide me more details),
> # Uninstall smpd from an ADMIN command prompt by typing, "smpd -uninstall"
> # Install smpd from the ADMIN command prompt by typing, "smpd -install -phrase behappy"
> # Check status of smpd from the ADMIN command prompt by typing, "smpd -status"
> # Run a non-MPI program from the ADMIN command prompt by typing, "mpiexec -n 2 hostname"
> Regards,
> Jayesh
> Sent: Tuesday, May 25, 2010 3:10:40 PM GMT -06:00 US/Canada Central
> Hi,
> I reinstalled MPICH and I does not modified the default SMPD
> passphrase provided in the user input textbox, it is behappy.
> After the installation I try to run a non-MPI program (mpiexec -n 2
> hostname) and I have the same error:
> I have the output:
> Please specify an authentication passphrase for smpd: I write behappy
> Aborting: unable to connect to User-PC
> Very thanks.
> Yessica Brinkmann
> 2010/5/25 Yessica Brinkmann <yessica.brinkmann at gmail.com>:
>> Hi,
>> Yes, I modified the default SMPD passphrase provided in the user input
>> textbox. The error is because I modified the passphrase or because I
>> provided an incorrect passphrase at the command line? Maybe I provided
>> an incorrect passphrase at the command line, maybe I should to
>> reinstall the MPICH2 and annotate the passphrase.
>> Thanks very much.
>> Yessica Brinkmann
>>> Hi,
>>> The error message shows that you did not specify an authentication passphrase for SMPD. If the installation process was successful you should not be seeing this message.
>>> During the installation process, the MPICH2 installer requests for the SMPD passphrase. A default SMPD passphrase is provided in the user input textbox for convenience. Did you delete/remove the default passphrase during the installation step ?
>>> Can you reply with details the steps used to install MPICH2 (You can add inputs to the installation steps that I provided in my previous email)? Also specify, in detail, if you modified any default input values during the installation process.
>>> Regards,
>>> Jayesh
>>> Sent: Tuesday, May 25, 2010 11:18:27 AM GMT -06:00 US/Canada Central
>>> Hi, Very thanks for your response.
>>> I reinstalled the MPICH2 by the steps that you say to me.
>>> I have the output:
>>> I write the authentication passphrase and the system response to me:
>>> Very thanks.
>>> Yessica Brinkmann
>>>> Hi,
>>>> I would recommend uninstalling MPICH2 and installing it again from the administrator command prompt by following the steps below.
>>>> # Download the latest version of MPICH2 (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads).
>>>> # Open an administrator command prompt (Right-click on the command prompt icon and select "Run as administrator")
>>>> # From the admin command prompt use the msiexec utility to uninstall MPICH2 (eg: Type "msiexec /x mpich2-1.2.1p1-win-ia32.msi" to uninstall MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>>>> # The above command will bring up the Installer GUI to uninstall MPICH2. Follow the steps to uninstall MPICH2.
>>>> # From the admin command prompt use the msiexec utility to install MPICH2 (eg: Type "msiexec /i mpich2-1.2.1p1-win-ia32.msi" to install MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>>>> # The above command will bring up the Installer GUI to install MPICH2. Follow the installer steps to install MPICH2.
>>>> # After the installation try to run a non-MPI program (mpiexec -n 2 hostname) . If the job launcher, mpiexec, requests for a username/password please provide the same (When specifying the username/password make sure that you specify the domain name if the user is a domain user).
>>>> Let us know the results.
>>>> Regards,
>>>> Jayesh
>>>> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
>>>> Sent: Monday, May 24, 2010 5:28:07 PM GMT -06:00 US/Canada Central
>>>> I sorry, I now open an administrative command prompt.
>>>> Now, when I write:
>>>> smpd -start
>>>> I have the output:
>>>> OpenService failed:
>>>> El servicio especificado no existe como servicio instalado (error 1060).
>>>> When I write:
>>>> smpd -install
>>>> I have the output:
>>>> MPICH Process Manager, Argonne National Lab installed.
>>>> Now, I write:
>>>> smpd -start
>>>> I have the output:
>>>> MPICH Process Manager, Argonne National Lab failed to start.
>>>> Ya se está ejecutando una instancia de este servicio (error 1056)
>>>> And when I write:
>>>> smpd -status
>>>> I have the output:
>>>> And when I write:
>>>> I have the output:
>>>> Yessica Brinkmann
>>>> 2010/5/24 Jayesh Krishna <jayesh at mcs.anl.gov>:
>>>>> Hi,
>>>>> This is strange. From the error messages it looks like you don't have admin privileges. Are you able to open an administrative command prompt (Right-click on command prompt icon - select "Run as administrator")?
>>>>> What is the output when you type "smpd -install" from the admin command prompt (You have to run the command from an administrator command prompt)?
>>>>> Regards,
>>>>> Jayesh
>>>>> Sent: Monday, May 24, 2010 5:02:14 PM GMT -06:00 US/Canada Central
>>>>> Hi, very thanks for your interest.
>>>>> When I type smpd -start the system response to me:
>>>>> OpenSCManager failed:
>>>>> Access denied (error 5)
>>>>> And when I type smpd -uninstall I have the same error:
>>>>> Very thanks, I will thanks any help.
>>>>> Yessica Brinkmann
>>>>> 2010/5/24 <jayesh at mcs.anl.gov>:
>>>>>> Hi,
>>>>>> Try starting smpd from the administrative command prompt (Type "smpd -start" from the administrative command prompt) and let us know the result.
>>>>>> If starting smpd (the step above) fails, try uninstalling+installing smpd from the admin command prompt (Type "smpd -uninstall" to uninstall SMPD and then type "smpd -install" to install SMPD) and let us know the results.
>>>>>> Regards,
>>>>>> Jayesh
>>>>>> Sent: Monday, May 24, 2010 4:40:44 PM GMT -06:00 US/Canada Central
>>>>>> Hi, Very thanks for your response!!!
>>>>>> I does not have error messages during MPICH2 installation. I turn off
>>>>>> the firewall for run mpiexec -n 2 hostname.
>>>>>> The output of "smpd -status" from an administrative command prompt is:
>>>>>> no smpd running on User-PC
>>>>>> I try running mpiexec -n 2 hostname from the administrative command
>>>>>> prompt and I have the same error:
>>>>>> Error while connectig to host, No se puede establecer una conexión ya
>>>>>> que el equipo de destino denegó expresamente dicha conexión (10061)
>>>>>> Connect on sock(host=User-PC, port=8676) failed, exhaused all end
>>>>>> points Unable to connect to 'User-PC:8678', sock error: Error = -1
>>>>>> Very thanks. I will thanks any help.
>>>>>> Yessica Brinkmann
>>>>>>> Hi,
>>>>>>> Did you get any error messages during MPICH2 installation ? Do you have any firewalls running on your machine (If so, turn off the firewall and re-run "mpiexec -n 2 hostname")?
>>>>>>> What is the output of "smpd -status" (Type "smpd -status" from an administrative command prompt)? Can you try running "mpiexec -n 2 hostname" from the administrative command prompt ?
>>>>>>> Regards,
>>>>>>> Jayesh
>>>>>>> Sent: Monday, May 24, 2010 4:03:51 PM GMT -06:00 US/Canada Central
>>>>>>> Hi, Very thanks for your response and your interest.
>>>>>>> I do all that you say to me, I reinstalled MPICH2.
>>>>>>> I try to run a non-MPI program (mpiexec -n 2 hostname) and I have the
>>>>>>> same error:
>>>>>>> Yessica Brinkmann
>>>>>>>> Hi,
>>>>>>>> Did you get any errors during the installation of MPICH2 ?
>>>>>>>> I would recommend the following,
>>>>>>>> # Uninstall MPICH2 from your system.
>>>>>>>> # Open an administrative command prompt (Right-click on the command prompt icon and select "Run as administrator")
>>>>>>>> # From the administrative command prompt use the msiexec utility to install MPICH2 (eg: Type "msiexec /i mpich2-1.2.1p1-win-ia32.msi" to install MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>>>>>>>> Regards,
>>>>>>>> Jayesh
>>>>>>>> (PS: Please reply to this email for further correspondence regarding this request - I have copied the email to mpich-discuss instead of mpich2-dev since the discussion is not related to mpich2 dev )
>>>>>>>> To: mpich2-dev at mcs.anl.gov
>>>>>>>> Sent: Friday, May 21, 2010 7:08:41 PM GMT -06:00 US/Canada Central
>>>>>>>> Very thanks for your response. I am using windows 7 and I execute at
>>>>>>>> windows comman line mpiexec -np 2 my_program.exe that you say to me,
>>>>>>>> at the MPICH2\bin directory.
>>>>>>>> And then I write the authentication passphrase that I write on the
>>>>>>>> MPICH instalation and the system response to me:
>>>>>>>> I will thanks you very much any help.
>>>>>>>> Thanks,
>>>>>>>> Yessica Brinkmann
>>>>>>>> 2010/5/21 Lisandro Dalcin <dalcinl at gmail.com>:
>>>>>>>>> On 21 May 2010 14:07, Yessica Brinkmann <yessica.brinkmann at gmail.com> wrote:
>>>>>>>>>> Hello.
>>>>>>>>> Hello, Yessica
>>>>>>>>>> I am using MPICH2. I am writing my first program in MPI.
>>>>>>>>> This mailing list is related to DEVELOPMENT of MPICH2, general (and
>>>>>>>>> pretty basic, in your case) user-level questions about MPI should be
>>>>>>>>> directed elsewhere.
>>>>>>>>>> I write the sentences:
>>>>>>>>>> int id;
>>>>>>>>>> MPI_Comm_rank (MPI_COMM_WORLD, & id);
>>>>>>>>>> if (id == 0)
>>>>>>>>>> / * Master task * /
>>>>>>>>>> else
>>>>>>>>>> / * Worker task * /
>>>>>>>>>> And I write other sentences. The issue is that it does not recognize a
>>>>>>>>>> DualCore processor, and takes the machine as it only has one
>>>>>>>>>> processor, indeed, never enters the else.
>>>>>>>>>> I would appreciate very much any help.
>>>>>>>>>> Sincerely,
>>>>>>>>>> Yessica Brinkmann
>>>>>>>>> After compiling your program:
>>>>>>>>> $ mpicc sourcecode.c -o myprogram
>>>>>>>>> you have to run it like this (requires first to "mpdboot"):
>>>>>>>>> $ mpiexec -n 2 ./myprogram
>>>>>>>>> of like this:
>>>>>>>>> $ mpiexec.hydra -n 2 ./myprogram
>>>>>>>>> Lisandro Dalcin
>>>>>>>>> CIMEC (INTEC/CONICET-UNL)
>>>>>>>>> Predio CONICET-Santa Fe
>>>>>>>>> Colectora RN 168 Km 472, Paraje El Pozo
>>>>>>>>> Tel: +54-342-4511594 (ext 1011)
>>>>>>>>> Tel/Fax: +54-342-4511169
