[mpich-discuss] [mpich2-dev] I can not make MPI recognizes a	dual core
    Yessica Brinkmann
    yessica.brinkmann at gmail.com
    Tue May 25 21:14:53 CDT 2010
Hi, very thanks for your response.
I created a new user called MPI and I reinstalled the MPICH2 only for
this user, and I executed the sentences that you say for me.
When I write
smpd -uninstall
The system response to me:
Stopping MPICH2 Process Manager, Argonne National Lab.
MPICH2 Process Manager, Argonne National Lab stopped.
MPICH2 Process Manager, Argonne National Lab removed.
When I write:
smpd -install -phrase behappy
MPICH2 Process Manager, Argonne National Lab installed.
When I write:
smpd -status
smpd running on User-PC
When I write:
mpiexec -n 2 hostname
User credentials needed to launch processes:
account(domain\user) [User-PC\MPI]:
And at this point I does not how I should write, I try with MPI or
User-PC\MPI, but does not work.
Then the system ask to me for the password:
I write the password that I use for the MPI user, and the system response to me:
Credentials for MPI rejected connecting to User-PC.
Aborting: Unable to connect to User-PC
I think this is because I does not known how I should write when the
system ask to me:
I will thanks any help.
Yessica Brinkmann
2010/5/25  <jayesh at mcs.anl.gov>:
> Hi,
>  This is strange... With the information provided by you I can only make the following suggestions (I can provide better suggestions if you provide me more details),
> # Uninstall smpd from an ADMIN command prompt by typing, "smpd -uninstall"
> # Install smpd from the ADMIN command prompt by typing, "smpd -install -phrase behappy"
> # Check status of smpd from the ADMIN command prompt by typing, "smpd -status"
> # Run a non-MPI program from the ADMIN command prompt by typing, "mpiexec -n 2 hostname"
> Regards,
> Jayesh
> From: "Yessica Brinkmann" <yessica.brinkmann at gmail.com>
> To: jayesh at mcs.anl.gov
> Cc: mpich-discuss at mcs.anl.gov
> Sent: Tuesday, May 25, 2010 3:10:40 PM GMT -06:00 US/Canada Central
> Subject: Re: [mpich2-dev] I can not make MPI recognizes a dual core
> Hi,
> I reinstalled MPICH and I does not modified the default SMPD
> passphrase provided in the user input textbox, it is behappy.
> After the installation I try to run a non-MPI program (mpiexec -n 2
> hostname) and I have the same error:
> I have the output:
> Please specify an authentication passphrase for smpd: I write behappy
> Aborting: unable to connect to User-PC
> Very thanks.
> Yessica Brinkmann
> 2010/5/25 Yessica Brinkmann <yessica.brinkmann at gmail.com>:
>> Hi,
>> Yes, I modified the default SMPD passphrase provided in the user input
>> textbox. The error is because I modified the passphrase or because I
>> provided an incorrect passphrase at the command line? Maybe I provided
>> an incorrect passphrase at the command line, maybe I should to
>> reinstall the MPICH2 and annotate the passphrase.
>> Thanks very much.
>> Yessica Brinkmann
>>> Hi,
>>>  The error message shows that you did not specify an authentication passphrase for SMPD. If the installation process was successful you should not be seeing this message.
>>>  During the installation process, the MPICH2 installer requests for the SMPD passphrase. A default SMPD passphrase is provided in the user input textbox for convenience. Did you delete/remove the default passphrase during the installation step ?
>>>  Can you reply with details the steps used to install MPICH2 (You can add inputs to the installation steps that I provided in my previous email)? Also specify, in detail, if you modified any default input values during the installation process.
>>> Regards,
>>> Jayesh
>>> Sent: Tuesday, May 25, 2010 11:18:27 AM GMT -06:00 US/Canada Central
>>> Hi, Very thanks for your response.
>>> I reinstalled the MPICH2 by the steps that you say to me.
>>> I have the output:
>>> I write the authentication passphrase and the system response to me:
>>> Very thanks.
>>> Yessica Brinkmann
>>>> Hi,
>>>>  I would recommend uninstalling MPICH2 and installing it again from the administrator command prompt by following the steps below.
>>>> # Download the latest version of MPICH2 (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads).
>>>> # Open an administrator command prompt (Right-click on the command prompt icon and select "Run as administrator")
>>>> # From the admin command prompt use the msiexec utility to uninstall MPICH2 (eg: Type "msiexec /x mpich2-1.2.1p1-win-ia32.msi" to uninstall MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>>>> # The above command will bring up the Installer GUI to uninstall MPICH2. Follow the steps to uninstall MPICH2.
>>>> # From the admin command prompt use the msiexec utility to install MPICH2 (eg: Type "msiexec /i mpich2-1.2.1p1-win-ia32.msi" to install MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>>>> # The above command will bring up the Installer GUI to install MPICH2. Follow the installer steps to install MPICH2.
>>>> # After the installation try to run a non-MPI program (mpiexec -n 2 hostname) . If the job launcher, mpiexec, requests for a username/password please provide the same (When specifying the username/password make sure that you specify the domain name if the user is a domain user).
>>>>  Let us know the results.
>>>> Regards,
>>>> Jayesh
>>>> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
>>>> Sent: Monday, May 24, 2010 5:28:07 PM GMT -06:00 US/Canada Central
>>>> I sorry, I now open an administrative command prompt.
>>>> Now, when I write:
>>>> smpd -start
>>>> I have the output:
>>>> OpenService failed:
>>>> El servicio especificado no existe como servicio instalado (error 1060).
>>>> When I write:
>>>> smpd -install
>>>> I have the output:
>>>> MPICH Process Manager, Argonne National Lab installed.
>>>> Now, I write:
>>>> smpd -start
>>>> I have the output:
>>>> MPICH Process Manager, Argonne National Lab failed to start.
>>>> Ya se está ejecutando una instancia de este servicio (error 1056)
>>>> And when I write:
>>>> smpd -status
>>>> I have the output:
>>>> And when I write:
>>>> I have the output:
>>>> Yessica Brinkmann
>>>> 2010/5/24 Jayesh Krishna <jayesh at mcs.anl.gov>:
>>>>> Hi,
>>>>>  This is strange. From the error messages it looks like you don't have admin privileges. Are you able to open an administrative command prompt (Right-click on command prompt icon - select "Run as administrator")?
>>>>>  What is the output when you type "smpd -install" from the admin command prompt (You have to run the command from an administrator command prompt)?
>>>>> Regards,
>>>>> Jayesh
>>>>> Sent: Monday, May 24, 2010 5:02:14 PM GMT -06:00 US/Canada Central
>>>>> Hi, very thanks for your interest.
>>>>> When I type smpd -start the system response to me:
>>>>> OpenSCManager failed:
>>>>> Access denied (error 5)
>>>>> And when I type smpd -uninstall I have the same error:
>>>>> Very thanks, I will thanks any help.
>>>>> Yessica Brinkmann
>>>>> 2010/5/24  <jayesh at mcs.anl.gov>:
>>>>>> Hi,
>>>>>>  Try starting smpd from the administrative command prompt (Type "smpd -start" from the administrative command prompt) and let us know the result.
>>>>>>  If starting smpd (the step above) fails, try uninstalling+installing smpd from the admin command prompt (Type "smpd -uninstall" to uninstall SMPD and then type "smpd -install" to install SMPD) and let us know the results.
>>>>>> Regards,
>>>>>> Jayesh
>>>>>> Sent: Monday, May 24, 2010 4:40:44 PM GMT -06:00 US/Canada Central
>>>>>> Hi, Very thanks for your response!!!
>>>>>> I does not have error messages during MPICH2 installation. I turn off
>>>>>> the firewall for run mpiexec -n 2 hostname.
>>>>>> The output of "smpd -status" from an administrative command prompt is:
>>>>>> no smpd running on User-PC
>>>>>> I try running mpiexec -n 2 hostname from the administrative command
>>>>>> prompt and I have the same error:
>>>>>> Error while connectig to host, No se puede establecer una conexión ya
>>>>>> que el equipo de destino denegó expresamente dicha conexión (10061)
>>>>>> Connect on sock(host=User-PC, port=8676) failed, exhaused all end
>>>>>> points Unable to connect to 'User-PC:8678', sock error: Error = -1
>>>>>> Very thanks. I will thanks any help.
>>>>>> Yessica Brinkmann
>>>>>>> Hi,
>>>>>>>  Did you get any error messages during MPICH2 installation ? Do you have any firewalls running on your machine (If so, turn off the firewall and re-run "mpiexec -n 2 hostname")?
>>>>>>>  What is the output of "smpd -status" (Type "smpd -status" from an administrative command prompt)? Can you try running "mpiexec -n 2 hostname" from the administrative command prompt ?
>>>>>>> Regards,
>>>>>>> Jayesh
>>>>>>> Sent: Monday, May 24, 2010 4:03:51 PM GMT -06:00 US/Canada Central
>>>>>>> Hi, Very thanks for your response and your interest.
>>>>>>> I do all that you say to me, I reinstalled MPICH2.
>>>>>>> I try to run a non-MPI program (mpiexec -n 2 hostname) and I have the
>>>>>>> same error:
>>>>>>> Yessica Brinkmann
>>>>>>>> Hi,
>>>>>>>>  Did you get any errors during the installation of MPICH2 ?
>>>>>>>>  I would recommend the following,
>>>>>>>> # Uninstall MPICH2 from your system.
>>>>>>>> # Open an administrative command prompt (Right-click on the command prompt icon and select "Run as administrator")
>>>>>>>> # From the administrative command prompt use the msiexec utility to install MPICH2 (eg: Type "msiexec /i mpich2-1.2.1p1-win-ia32.msi" to install MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>>>>>>>> Regards,
>>>>>>>> Jayesh
>>>>>>>> (PS: Please reply to this email for further correspondence regarding this request - I have copied the email to mpich-discuss instead of mpich2-dev since the discussion is not related to mpich2 dev )
>>>>>>>> To: mpich2-dev at mcs.anl.gov
>>>>>>>> Sent: Friday, May 21, 2010 7:08:41 PM GMT -06:00 US/Canada Central
>>>>>>>> Very thanks for your response. I am using windows 7 and I execute at
>>>>>>>> windows comman line mpiexec -np 2 my_program.exe that you say to me,
>>>>>>>> at the MPICH2\bin directory.
>>>>>>>> And then I write the authentication passphrase that I write on the
>>>>>>>> MPICH instalation and the system response to me:
>>>>>>>> I will thanks you very much any help.
>>>>>>>> Thanks,
>>>>>>>> Yessica Brinkmann
>>>>>>>> 2010/5/21 Lisandro Dalcin <dalcinl at gmail.com>:
>>>>>>>>> On 21 May 2010 14:07, Yessica Brinkmann <yessica.brinkmann at gmail.com> wrote:
>>>>>>>>>> Hello.
>>>>>>>>> Hello, Yessica
>>>>>>>>>> I am using MPICH2. I am writing my first program in MPI.
>>>>>>>>> This mailing list is related to DEVELOPMENT of MPICH2, general (and
>>>>>>>>> pretty basic, in your case) user-level questions about MPI should be
>>>>>>>>> directed elsewhere.
>>>>>>>>>> I write the sentences:
>>>>>>>>>> int id;
>>>>>>>>>> MPI_Comm_rank (MPI_COMM_WORLD, & id);
>>>>>>>>>> if (id == 0)
>>>>>>>>>> / * Master task * /
>>>>>>>>>> else
>>>>>>>>>> / * Worker task * /
>>>>>>>>>> And I write other sentences. The issue is that it does not recognize a
>>>>>>>>>> DualCore processor, and takes the machine as it only has one
>>>>>>>>>> processor, indeed, never enters the else.
>>>>>>>>>> I would appreciate very much any help.
>>>>>>>>>> Sincerely,
>>>>>>>>>> Yessica Brinkmann
>>>>>>>>> After compiling your program:
>>>>>>>>> $ mpicc sourcecode.c -o myprogram
>>>>>>>>> you have to run it like this (requires first to "mpdboot"):
>>>>>>>>> $ mpiexec -n 2 ./myprogram
>>>>>>>>> of like this:
>>>>>>>>> $ mpiexec.hydra -n 2 ./myprogram
>>>>>>>>> Lisandro Dalcin
>>>>>>>>> CIMEC (INTEC/CONICET-UNL)
>>>>>>>>> Predio CONICET-Santa Fe
>>>>>>>>> Colectora RN 168 Km 472, Paraje El Pozo
>>>>>>>>> Tel: +54-342-4511594 (ext 1011)
>>>>>>>>> Tel/Fax: +54-342-4511169
