[mpich-discuss] [mpich2-dev] I can not make MPI recognizes a	dual core
    Yessica Brinkmann
    yessica.brinkmann at gmail.com
    Tue May 25 13:42:46 CDT 2010
Yes, I modified the default SMPD passphrase provided in the user input
textbox. The error is because I modified the passphrase or because I
provided an incorrect passphrase at the command line? Maybe I provided
an incorrect passphrase at the command line, maybe I should to
reinstall the MPICH2 and annotate the passphrase.
Thanks very much.
Yessica Brinkmann
2010/5/25  <jayesh at mcs.anl.gov>:
> Hi,
>  The error message shows that you did not specify an authentication passphrase for SMPD. If the installation process was successful you should not be seeing this message.
>  During the installation process, the MPICH2 installer requests for the SMPD passphrase. A default SMPD passphrase is provided in the user input textbox for convenience. Did you delete/remove the default passphrase during the installation step ?
>  Can you reply with details the steps used to install MPICH2 (You can add inputs to the installation steps that I provided in my previous email)? Also specify, in detail, if you modified any default input values during the installation process.
> Regards,
> Jayesh
> From: "Yessica Brinkmann" <yessica.brinkmann at gmail.com>
> To: jayesh at mcs.anl.gov
> Cc: mpich-discuss at mcs.anl.gov
> Sent: Tuesday, May 25, 2010 11:18:27 AM GMT -06:00 US/Canada Central
> Subject: Re: [mpich2-dev] I can not make MPI recognizes a dual core
> Hi, Very thanks for your response.
> I reinstalled the MPICH2 by the steps that you say to me.
> After the installation I try to run a non-MPI program (mpiexec -n 2
> hostname) and I have the same error:
> I have the output:
> Please specify an authentication passphrase for smpd:
> I write the authentication passphrase and the system response to me:
> Aborting: unable to connect to User-PC
> Very thanks.
> I will thanks any help.
> Yessica Brinkmann
>> Hi,
>>  I would recommend uninstalling MPICH2 and installing it again from the administrator command prompt by following the steps below.
>> # Download the latest version of MPICH2 (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads).
>> # Open an administrator command prompt (Right-click on the command prompt icon and select "Run as administrator")
>> # From the admin command prompt use the msiexec utility to uninstall MPICH2 (eg: Type "msiexec /x mpich2-1.2.1p1-win-ia32.msi" to uninstall MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>> # The above command will bring up the Installer GUI to uninstall MPICH2. Follow the steps to uninstall MPICH2.
>> # From the admin command prompt use the msiexec utility to install MPICH2 (eg: Type "msiexec /i mpich2-1.2.1p1-win-ia32.msi" to install MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>> # The above command will bring up the Installer GUI to install MPICH2. Follow the installer steps to install MPICH2.
>> # After the installation try to run a non-MPI program (mpiexec -n 2 hostname) . If the job launcher, mpiexec, requests for a username/password please provide the same (When specifying the username/password make sure that you specify the domain name if the user is a domain user).
>>  Let us know the results.
>> Regards,
>> Jayesh
>> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
>> Sent: Monday, May 24, 2010 5:28:07 PM GMT -06:00 US/Canada Central
>> I sorry, I now open an administrative command prompt.
>> Now, when I write:
>> smpd -start
>> I have the output:
>> OpenService failed:
>> El servicio especificado no existe como servicio instalado (error 1060).
>> When I write:
>> smpd -install
>> I have the output:
>> MPICH Process Manager, Argonne National Lab installed.
>> Now, I write:
>> smpd -start
>> I have the output:
>> MPICH Process Manager, Argonne National Lab failed to start.
>> Ya se está ejecutando una instancia de este servicio (error 1056)
>> And when I write:
>> smpd -status
>> I have the output:
>> And when I write:
>> I have the output:
>> Yessica Brinkmann
>> 2010/5/24 Jayesh Krishna <jayesh at mcs.anl.gov>:
>>> Hi,
>>>  This is strange. From the error messages it looks like you don't have admin privileges. Are you able to open an administrative command prompt (Right-click on command prompt icon - select "Run as administrator")?
>>>  What is the output when you type "smpd -install" from the admin command prompt (You have to run the command from an administrator command prompt)?
>>> Regards,
>>> Jayesh
>>> Sent: Monday, May 24, 2010 5:02:14 PM GMT -06:00 US/Canada Central
>>> Hi, very thanks for your interest.
>>> When I type smpd -start the system response to me:
>>> OpenSCManager failed:
>>> Access denied (error 5)
>>> And when I type smpd -uninstall I have the same error:
>>> Very thanks, I will thanks any help.
>>> Yessica Brinkmann
>>> 2010/5/24  <jayesh at mcs.anl.gov>:
>>>> Hi,
>>>>  Try starting smpd from the administrative command prompt (Type "smpd -start" from the administrative command prompt) and let us know the result.
>>>>  If starting smpd (the step above) fails, try uninstalling+installing smpd from the admin command prompt (Type "smpd -uninstall" to uninstall SMPD and then type "smpd -install" to install SMPD) and let us know the results.
>>>> Regards,
>>>> Jayesh
>>>> Sent: Monday, May 24, 2010 4:40:44 PM GMT -06:00 US/Canada Central
>>>> Hi, Very thanks for your response!!!
>>>> I does not have error messages during MPICH2 installation. I turn off
>>>> the firewall for run mpiexec -n 2 hostname.
>>>> The output of "smpd -status" from an administrative command prompt is:
>>>> no smpd running on User-PC
>>>> I try running mpiexec -n 2 hostname from the administrative command
>>>> prompt and I have the same error:
>>>> Error while connectig to host, No se puede establecer una conexión ya
>>>> que el equipo de destino denegó expresamente dicha conexión (10061)
>>>> Connect on sock(host=User-PC, port=8676) failed, exhaused all end
>>>> points Unable to connect to 'User-PC:8678', sock error: Error = -1
>>>> Very thanks. I will thanks any help.
>>>> Yessica Brinkmann
>>>>> Hi,
>>>>>  Did you get any error messages during MPICH2 installation ? Do you have any firewalls running on your machine (If so, turn off the firewall and re-run "mpiexec -n 2 hostname")?
>>>>>  What is the output of "smpd -status" (Type "smpd -status" from an administrative command prompt)? Can you try running "mpiexec -n 2 hostname" from the administrative command prompt ?
>>>>> Regards,
>>>>> Jayesh
>>>>> Sent: Monday, May 24, 2010 4:03:51 PM GMT -06:00 US/Canada Central
>>>>> Hi, Very thanks for your response and your interest.
>>>>> I do all that you say to me, I reinstalled MPICH2.
>>>>> I try to run a non-MPI program (mpiexec -n 2 hostname) and I have the
>>>>> same error:
>>>>> Yessica Brinkmann
>>>>>> Hi,
>>>>>>  Did you get any errors during the installation of MPICH2 ?
>>>>>>  I would recommend the following,
>>>>>> # Uninstall MPICH2 from your system.
>>>>>> # Open an administrative command prompt (Right-click on the command prompt icon and select "Run as administrator")
>>>>>> # From the administrative command prompt use the msiexec utility to install MPICH2 (eg: Type "msiexec /i mpich2-1.2.1p1-win-ia32.msi" to install MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>>>>>> Regards,
>>>>>> Jayesh
>>>>>> (PS: Please reply to this email for further correspondence regarding this request - I have copied the email to mpich-discuss instead of mpich2-dev since the discussion is not related to mpich2 dev )
>>>>>> To: mpich2-dev at mcs.anl.gov
>>>>>> Sent: Friday, May 21, 2010 7:08:41 PM GMT -06:00 US/Canada Central
>>>>>> Very thanks for your response. I am using windows 7 and I execute at
>>>>>> windows comman line mpiexec -np 2 my_program.exe that you say to me,
>>>>>> at the MPICH2\bin directory.
>>>>>> The system response to me:
>>>>>> And then I write the authentication passphrase that I write on the
>>>>>> MPICH instalation and the system response to me:
>>>>>> I will thanks you very much any help.
>>>>>> Thanks,
>>>>>> Yessica Brinkmann
>>>>>> 2010/5/21 Lisandro Dalcin <dalcinl at gmail.com>:
>>>>>>> On 21 May 2010 14:07, Yessica Brinkmann <yessica.brinkmann at gmail.com> wrote:
>>>>>>>> Hello.
>>>>>>> Hello, Yessica
>>>>>>>> I am using MPICH2. I am writing my first program in MPI.
>>>>>>> This mailing list is related to DEVELOPMENT of MPICH2, general (and
>>>>>>> pretty basic, in your case) user-level questions about MPI should be
>>>>>>> directed elsewhere.
>>>>>>>> I write the sentences:
>>>>>>>> int id;
>>>>>>>> MPI_Comm_rank (MPI_COMM_WORLD, & id);
>>>>>>>> if (id == 0)
>>>>>>>> / * Master task * /
>>>>>>>> else
>>>>>>>> / * Worker task * /
>>>>>>>> And I write other sentences. The issue is that it does not recognize a
>>>>>>>> DualCore processor, and takes the machine as it only has one
>>>>>>>> processor, indeed, never enters the else.
>>>>>>>> I would appreciate very much any help.
>>>>>>>> Sincerely,
>>>>>>>> Yessica Brinkmann
>>>>>>> After compiling your program:
>>>>>>> $ mpicc sourcecode.c -o myprogram
>>>>>>> you have to run it like this (requires first to "mpdboot"):
>>>>>>> $ mpiexec -n 2 ./myprogram
>>>>>>> of like this:
>>>>>>> $ mpiexec.hydra -n 2 ./myprogram
>>>>>>> Lisandro Dalcin
>>>>>>> CIMEC (INTEC/CONICET-UNL)
>>>>>>> Predio CONICET-Santa Fe
>>>>>>> Colectora RN 168 Km 472, Paraje El Pozo
>>>>>>> Tel: +54-342-4511594 (ext 1011)
>>>>>>> Tel/Fax: +54-342-4511169
