[mpich-discuss] [mpich2-dev] I can not make MPI recognizes a	dual core
    Yessica Brinkmann
    yessica.brinkmann at gmail.com
    Tue May 25 11:18:27 CDT 2010
Hi, Very thanks for your response.
I reinstalled the MPICH2 by the steps that you say to me.
After the installation I try to run a non-MPI program (mpiexec -n 2
hostname) and I have the same error:
I have the output:
Please specify an authentication passphrase for smpd:
I write the authentication passphrase and the system response to me:
Aborting: unable to connect to User-PC
Very thanks.
I will thanks any help.
Yessica Brinkmann
2010/5/25  <jayesh at mcs.anl.gov>:
> Hi,
>  I would recommend uninstalling MPICH2 and installing it again from the administrator command prompt by following the steps below.
> # Download the latest version of MPICH2 (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads).
> # Open an administrator command prompt (Right-click on the command prompt icon and select "Run as administrator")
> # From the admin command prompt use the msiexec utility to uninstall MPICH2 (eg: Type "msiexec /x mpich2-1.2.1p1-win-ia32.msi" to uninstall MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
> # The above command will bring up the Installer GUI to uninstall MPICH2. Follow the steps to uninstall MPICH2.
> # From the admin command prompt use the msiexec utility to install MPICH2 (eg: Type "msiexec /i mpich2-1.2.1p1-win-ia32.msi" to install MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
> # The above command will bring up the Installer GUI to install MPICH2. Follow the installer steps to install MPICH2.
> # After the installation try to run a non-MPI program (mpiexec -n 2 hostname) . If the job launcher, mpiexec, requests for a username/password please provide the same (When specifying the username/password make sure that you specify the domain name if the user is a domain user).
>  Let us know the results.
> Regards,
> Jayesh
> From: "Yessica Brinkmann" <yessica.brinkmann at gmail.com>
> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
> Cc: mpich-discuss at mcs.anl.gov
> Sent: Monday, May 24, 2010 5:28:07 PM GMT -06:00 US/Canada Central
> Subject: Re: [mpich2-dev] I can not make MPI recognizes a dual core
> I sorry, I now open an administrative command prompt.
> Now, when I write:
> smpd -start
> I have the output:
> OpenService failed:
> El servicio especificado no existe como servicio instalado (error 1060).
> When I write:
> smpd -install
> I have the output:
> MPICH Process Manager, Argonne National Lab installed.
> Now, I write:
> smpd -start
> I have the output:
> MPICH Process Manager, Argonne National Lab failed to start.
> Ya se está ejecutando una instancia de este servicio (error 1056)
> And when I write:
> smpd -status
> I have the output:
> And when I write:
> I have the output:
> Yessica Brinkmann
> 2010/5/24 Jayesh Krishna <jayesh at mcs.anl.gov>:
>> Hi,
>>  This is strange. From the error messages it looks like you don't have admin privileges. Are you able to open an administrative command prompt (Right-click on command prompt icon - select "Run as administrator")?
>>  What is the output when you type "smpd -install" from the admin command prompt (You have to run the command from an administrator command prompt)?
>> Regards,
>> Jayesh
>> To: jayesh at mcs.anl.gov
>> Sent: Monday, May 24, 2010 5:02:14 PM GMT -06:00 US/Canada Central
>> Hi, very thanks for your interest.
>> When I type smpd -start the system response to me:
>> OpenSCManager failed:
>> Access denied (error 5)
>> And when I type smpd -uninstall I have the same error:
>> Very thanks, I will thanks any help.
>> Yessica Brinkmann
>> 2010/5/24  <jayesh at mcs.anl.gov>:
>>> Hi,
>>>  Try starting smpd from the administrative command prompt (Type "smpd -start" from the administrative command prompt) and let us know the result.
>>>  If starting smpd (the step above) fails, try uninstalling+installing smpd from the admin command prompt (Type "smpd -uninstall" to uninstall SMPD and then type "smpd -install" to install SMPD) and let us know the results.
>>> Regards,
>>> Jayesh
>>> Sent: Monday, May 24, 2010 4:40:44 PM GMT -06:00 US/Canada Central
>>> Hi, Very thanks for your response!!!
>>> I does not have error messages during MPICH2 installation. I turn off
>>> the firewall for run mpiexec -n 2 hostname.
>>> The output of "smpd -status" from an administrative command prompt is:
>>> no smpd running on User-PC
>>> I try running mpiexec -n 2 hostname from the administrative command
>>> prompt and I have the same error:
>>> Error while connectig to host, No se puede establecer una conexión ya
>>> que el equipo de destino denegó expresamente dicha conexión (10061)
>>> Connect on sock(host=User-PC, port=8676) failed, exhaused all end
>>> points Unable to connect to 'User-PC:8678', sock error: Error = -1
>>> Very thanks. I will thanks any help.
>>> Yessica Brinkmann
>>>> Hi,
>>>>  Did you get any error messages during MPICH2 installation ? Do you have any firewalls running on your machine (If so, turn off the firewall and re-run "mpiexec -n 2 hostname")?
>>>>  What is the output of "smpd -status" (Type "smpd -status" from an administrative command prompt)? Can you try running "mpiexec -n 2 hostname" from the administrative command prompt ?
>>>> Regards,
>>>> Jayesh
>>>> Sent: Monday, May 24, 2010 4:03:51 PM GMT -06:00 US/Canada Central
>>>> Hi, Very thanks for your response and your interest.
>>>> I do all that you say to me, I reinstalled MPICH2.
>>>> I try to run a non-MPI program (mpiexec -n 2 hostname) and I have the
>>>> same error:
>>>> Yessica Brinkmann
>>>>> Hi,
>>>>>  Did you get any errors during the installation of MPICH2 ?
>>>>>  I would recommend the following,
>>>>> # Uninstall MPICH2 from your system.
>>>>> # Open an administrative command prompt (Right-click on the command prompt icon and select "Run as administrator")
>>>>> # From the administrative command prompt use the msiexec utility to install MPICH2 (eg: Type "msiexec /i mpich2-1.2.1p1-win-ia32.msi" to install MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>>>>> Regards,
>>>>> Jayesh
>>>>> (PS: Please reply to this email for further correspondence regarding this request - I have copied the email to mpich-discuss instead of mpich2-dev since the discussion is not related to mpich2 dev )
>>>>> To: mpich2-dev at mcs.anl.gov
>>>>> Sent: Friday, May 21, 2010 7:08:41 PM GMT -06:00 US/Canada Central
>>>>> Very thanks for your response. I am using windows 7 and I execute at
>>>>> windows comman line mpiexec -np 2 my_program.exe that you say to me,
>>>>> at the MPICH2\bin directory.
>>>>> The system response to me:
>>>>> And then I write the authentication passphrase that I write on the
>>>>> MPICH instalation and the system response to me:
>>>>> I will thanks you very much any help.
>>>>> Thanks,
>>>>> Yessica Brinkmann
>>>>> 2010/5/21 Lisandro Dalcin <dalcinl at gmail.com>:
>>>>>> On 21 May 2010 14:07, Yessica Brinkmann <yessica.brinkmann at gmail.com> wrote:
>>>>>>> Hello.
>>>>>> Hello, Yessica
>>>>>>> I am using MPICH2. I am writing my first program in MPI.
>>>>>> This mailing list is related to DEVELOPMENT of MPICH2, general (and
>>>>>> pretty basic, in your case) user-level questions about MPI should be
>>>>>> directed elsewhere.
>>>>>>> I write the sentences:
>>>>>>> int id;
>>>>>>> MPI_Comm_rank (MPI_COMM_WORLD, & id);
>>>>>>> if (id == 0)
>>>>>>> / * Master task * /
>>>>>>> else
>>>>>>> / * Worker task * /
>>>>>>> And I write other sentences. The issue is that it does not recognize a
>>>>>>> DualCore processor, and takes the machine as it only has one
>>>>>>> processor, indeed, never enters the else.
>>>>>>> I would appreciate very much any help.
>>>>>>> Sincerely,
>>>>>>> Yessica Brinkmann
>>>>>> After compiling your program:
>>>>>> $ mpicc sourcecode.c -o myprogram
>>>>>> you have to run it like this (requires first to "mpdboot"):
>>>>>> $ mpiexec -n 2 ./myprogram
>>>>>> of like this:
>>>>>> $ mpiexec.hydra -n 2 ./myprogram
>>>>>> Lisandro Dalcin
>>>>>> CIMEC (INTEC/CONICET-UNL)
>>>>>> Predio CONICET-Santa Fe
>>>>>> Colectora RN 168 Km 472, Paraje El Pozo
>>>>>> Tel: +54-342-4511594 (ext 1011)
>>>>>> Tel/Fax: +54-342-4511169
