[mpich-discuss] [mpich2-dev] I can not make MPI recognizes a dual core
jayesh at mcs.anl.gov
Tue May 25 08:08:32 CDT 2010
I would recommend uninstalling MPICH2 and installing it again from the administrator command prompt by following the steps below.
# Download the latest version of MPICH2 (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads).
# Open an administrator command prompt (Right-click on the command prompt icon and select "Run as administrator")
# From the admin command prompt use the msiexec utility to uninstall MPICH2 (eg: Type "msiexec /x mpich2-1.2.1p1-win-ia32.msi" to uninstall MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
# The above command will bring up the Installer GUI to uninstall MPICH2. Follow the steps to uninstall MPICH2.
# From the admin command prompt use the msiexec utility to install MPICH2 (eg: Type "msiexec /i mpich2-1.2.1p1-win-ia32.msi" to install MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
# The above command will bring up the Installer GUI to install MPICH2. Follow the installer steps to install MPICH2.
# After the installation try to run a non-MPI program (mpiexec -n 2 hostname) . If the job launcher, mpiexec, requests for a username/password please provide the same (When specifying the username/password make sure that you specify the domain name if the user is a domain user).
Let us know the results.
Jayesh
----- Original Message -----
From: "Yessica Brinkmann" <yessica.brinkmann at gmail.com>
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich-discuss at mcs.anl.gov
Sent: Monday, May 24, 2010 5:28:07 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich2-dev] I can not make MPI recognizes a dual core
Hi, Very thanks for your response.
I sorry, I now open an administrative command prompt.
Now, when I write:
smpd -start
I have the output:
OpenService failed:
El servicio especificado no existe como servicio instalado (error 1060).
When I write:
smpd -install
I have the output:
MPICH Process Manager, Argonne National Lab installed.
Now, I write:
smpd -start
I have the output:
MPICH Process Manager, Argonne National Lab failed to start.
Ya se está ejecutando una instancia de este servicio (error 1056)
And when I write:
smpd -status
I have the output:
Please specify an authentication passphrase for smpd:
I write the authentication passphrase and the system response to me:
Aborting: unable to connect to User-PC
And when I write:
I have the output:
I will thanks any help.
Yessica Brinkmann
2010/5/24 Jayesh Krishna <jayesh at mcs.anl.gov>:
> Hi,
> This is strange. From the error messages it looks like you don't have admin privileges. Are you able to open an administrative command prompt (Right-click on command prompt icon - select "Run as administrator")?
> What is the output when you type "smpd -install" from the admin command prompt (You have to run the command from an administrator command prompt)?
> Regards,
> Jayesh
> To: jayesh at mcs.anl.gov
> Sent: Monday, May 24, 2010 5:02:14 PM GMT -06:00 US/Canada Central
> Hi, very thanks for your interest.
> When I type smpd -start the system response to me:
> OpenSCManager failed:
> Access denied (error 5)
> And when I type smpd -uninstall I have the same error:
> Very thanks, I will thanks any help.
> Yessica Brinkmann
> 2010/5/24 <jayesh at mcs.anl.gov>:
>> Hi,
>> Try starting smpd from the administrative command prompt (Type "smpd -start" from the administrative command prompt) and let us know the result.
>> If starting smpd (the step above) fails, try uninstalling+installing smpd from the admin command prompt (Type "smpd -uninstall" to uninstall SMPD and then type "smpd -install" to install SMPD) and let us know the results.
>> Regards,
>> Jayesh
>> Sent: Monday, May 24, 2010 4:40:44 PM GMT -06:00 US/Canada Central
>> Hi, Very thanks for your response!!!
>> I does not have error messages during MPICH2 installation. I turn off
>> the firewall for run mpiexec -n 2 hostname.
>> The output of "smpd -status" from an administrative command prompt is:
>> no smpd running on User-PC
>> I try running mpiexec -n 2 hostname from the administrative command
>> prompt and I have the same error:
>> Error while connectig to host, No se puede establecer una conexión ya
>> que el equipo de destino denegó expresamente dicha conexión (10061)
>> Connect on sock(host=User-PC, port=8676) failed, exhaused all end
>> points Unable to connect to 'User-PC:8678', sock error: Error = -1
>> Very thanks. I will thanks any help.
>> Yessica Brinkmann
>>> Hi,
>>> Did you get any error messages during MPICH2 installation ? Do you have any firewalls running on your machine (If so, turn off the firewall and re-run "mpiexec -n 2 hostname")?
>>> What is the output of "smpd -status" (Type "smpd -status" from an administrative command prompt)? Can you try running "mpiexec -n 2 hostname" from the administrative command prompt ?
>>> Regards,
>>> Jayesh
>>> Sent: Monday, May 24, 2010 4:03:51 PM GMT -06:00 US/Canada Central
>>> Hi, Very thanks for your response and your interest.
>>> I do all that you say to me, I reinstalled MPICH2.
>>> I try to run a non-MPI program (mpiexec -n 2 hostname) and I have the
>>> same error:
>>> Yessica Brinkmann
>>>> Hi,
>>>> Did you get any errors during the installation of MPICH2 ?
>>>> I would recommend the following,
>>>> # Uninstall MPICH2 from your system.
>>>> # Open an administrative command prompt (Right-click on the command prompt icon and select "Run as administrator")
>>>> # From the administrative command prompt use the msiexec utility to install MPICH2 (eg: Type "msiexec /i mpich2-1.2.1p1-win-ia32.msi" to install MPICH2 using the mpich2-1.2.1p1-win-ia32.msi installer)
>>>> Regards,
>>>> Jayesh
>>>> (PS: Please reply to this email for further correspondence regarding this request - I have copied the email to mpich-discuss instead of mpich2-dev since the discussion is not related to mpich2 dev )
>>>> To: mpich2-dev at mcs.anl.gov
>>>> Sent: Friday, May 21, 2010 7:08:41 PM GMT -06:00 US/Canada Central
>>>> Very thanks for your response. I am using windows 7 and I execute at
>>>> windows comman line mpiexec -np 2 my_program.exe that you say to me,
>>>> at the MPICH2\bin directory.
>>>> The system response to me:
>>>> And then I write the authentication passphrase that I write on the
>>>> MPICH instalation and the system response to me:
>>>> I will thanks you very much any help.
>>>> Thanks,
>>>> Yessica Brinkmann
>>>> 2010/5/21 Lisandro Dalcin <dalcinl at gmail.com>:
>>>>> On 21 May 2010 14:07, Yessica Brinkmann <yessica.brinkmann at gmail.com> wrote:
>>>>>> Hello.
>>>>> Hello, Yessica
>>>>>> I am using MPICH2. I am writing my first program in MPI.
>>>>> This mailing list is related to DEVELOPMENT of MPICH2, general (and
>>>>> pretty basic, in your case) user-level questions about MPI should be
>>>>> directed elsewhere.
>>>>>> I write the sentences:
>>>>>> int id;
>>>>>> MPI_Comm_rank (MPI_COMM_WORLD, & id);
>>>>>> if (id == 0)
>>>>>> / * Master task * /
>>>>>> else
>>>>>> / * Worker task * /
>>>>>> And I write other sentences. The issue is that it does not recognize a
>>>>>> DualCore processor, and takes the machine as it only has one
>>>>>> processor, indeed, never enters the else.
>>>>>> I would appreciate very much any help.
>>>>>> Sincerely,
>>>>>> Yessica Brinkmann
>>>>> After compiling your program:
>>>>> $ mpicc sourcecode.c -o myprogram
>>>>> you have to run it like this (requires first to "mpdboot"):
>>>>> $ mpiexec -n 2 ./myprogram
>>>>> of like this:
>>>>> $ mpiexec.hydra -n 2 ./myprogram
>>>>> Lisandro Dalcin
>>>>> CIMEC (INTEC/CONICET-UNL)
>>>>> Predio CONICET-Santa Fe
>>>>> Colectora RN 168 Km 472, Paraje El Pozo
>>>>> Tel: +54-342-4511594 (ext 1011)
>>>>> Tel/Fax: +54-342-4511169
