[mpich-discuss] Acquiring mpic++ or similar MPI wrapper compilers
Jayesh Krishna
jayesh at mcs.anl.gov
Mon May 24 09:05:37 CDT 2010
We distribute pre-compiled windows libraries with the MPICH2 installer on windows. We do not provide any compiler wrappers as of now. Users typically use a compiler like VS and explicitly specify the include/lib path and the libraries to compile their MPI programs.
If you are still having problems let us know and I can modify the boost makefile for you.
Jayesh
----- Original Message -----
Sent: Monday, May 24, 2010 3:46:11 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] Acquiring mpic++ or similar MPI wrapper compilers
I am trying to compile a Boost MPI by following the instruction on http://www.boost.org/doc/libs/1_43_0/doc/html/mpi/getting_started.html#mpi.config
Right now, I am trying the listed MPI implementation, and I am stuck on one issue: I cannot find mpic++. In the bin directory of MPICH2, I see that there is mpiexec.exe, along with other binaries, but no mpic++. I downloaded the Windows IA32 (binary) file, so there is no need to build, am I correct? In this case, if I am to acquire mpic++ or similar MPI wrapper compiler, how do I acquire one?
mpich-discuss mailing list
