[mpich-discuss] try to install MPICH2 on SGI under local account
Mei, Rui rum06003 at engr.uconn.edu
Mon May 24 08:42:14 CDT 2010
Hi, Pavan,
Here are attached configure log file, make log file and Makefile. And the files required for running MPI are not installed, e.g.,
in the /u/home/rum06003/mpi/bin directory, there are only three files: mpiexec.gforker  mpiexec.hydra  pmi_proxy.
Thank you very much.
Rui
From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Pavan Balaji [balaji at mcs.anl.gov]
Sent: Sunday, May 23, 2010 10:22 PM
Subject: Re: [mpich-discuss] try to install MPICH2 on SGI under local account
It looks like some of the variables in your makefile are not set. Can
you send us the top-level config.log and Makefile?
Btw, only the documentation didn't get installed. The files required for
running MPI applications should already be installed before this error,
I think.
  -- Pavan
On 05/23/2010 07:43 PM, Mei, Rui wrote:
> Hi, all,
> Attached is the mi.txt file for your notice. I am desperately hoping to install mpi on this machine for my research model.
> I really appreciate your help.
> Rui
> From: Mei, Rui
> Sent: Sunday, May 23, 2010 8:36 PM
> Subject: RE: [mpich-discuss] try to install MPICH2 on SGI under local account
> Hi, Pavan,
> Thanks for your help. Now I can pass the configure step but get stuck at the install step while I was executing
> 'make install 2>&1 | tee mi.txt'.  Here is the error message. I am looking forward to help from you or someone who can
> kindly offer some clues.  Is it because I am under my own account instead of root account?
> /usr/bin/install -c -m 644 MPI_Win_set_errhandler.html /www3/MPI_Win_set_errhandler.html
> /usr/bin/install: cannot create regular file `/www3/MPI_Win_set_errhandler.html': No such file or directory
> /usr/bin/install -c -m 644 MPI_Win_set_name.html /www3/MPI_Win_set_name.html
> /usr/bin/install: cannot create regular file `/www3/MPI_Win_set_name.html': No such file or directory
> /usr/bin/install -c -m 644 MPI_Win_start.html /www3/MPI_Win_start.html
> /usr/bin/install: cannot create regular file `/www3/MPI_Win_start.html': No such file or directory
> /usr/bin/install -c -m 644 MPI_Win_test.html /www3/MPI_Win_test.html
> /usr/bin/install: cannot create regular file `/www3/MPI_Win_test.html': No such file or directory/usr/bin/install -c -m 644 MPI_Win_unlock.html /www3/MPI_Win_unlock.html
> /usr/bin/install: cannot create regular file `/www3/MPI_Win_unlock.html': No such file or directory
> /usr/bin/install -c -m 644 MPI_Win_wait.html /www3/MPI_Win_wait.html
> /usr/bin/install: cannot create regular file `/www3/MPI_Win_wait.html': No such file or directory/usr/bin/install -c -m 644 MPI_Wtick.html /www3/MPI_Wtick.html
> /usr/bin/install: cannot create regular file `/www3/MPI_Wtick.html': No such file or directory
> /usr/bin/install -c -m 644 MPI_Wtime.html /www3/MPI_Wtime.html
> /usr/bin/install: cannot create regular file `/www3/MPI_Wtime.html': No such file or directory
> make: *** [install] Error 1
> rum06003 at linuxAltix:~/mpich2-1.1>
> Rui
> Sent: Sunday, May 23, 2010 7:10 PM
> Rui,
> MPICH2's current default channel (ch3:nemesis) uses CPU atomic
> operations for performance issues. Since these are architecture
> specific, some architectures are natively supported and for some others
> we need to emulate these atomics (which obviously loses performance).
> The two options in such cases are:
> 1. Use the emulated atomic operations by specifying the
> --with-atomic-primitives=no option to configure.
> 2. Build MPICH2 with a different channel (ch3:sock) which does not use
> these atomic operations by specifying the --with-device=ch3:sock option
> to configure.
> The second option might perform a little better amongst the two, but
> both options will have some performance penalty compared to
> architectures where atomics are natively supported.
>   -- Pavan
> On 05/23/2010 06:02 PM, Mei, Rui wrote:
>> Hi, all,
>> I am trying to install MPICH2-1.2.1 under my local directory on SGI machine with system information"Linux linuxAltix 2.6.5-7.252-sn2 #1 SMP Tue Feb 14 11:11:04 UTC 2006 ia64 ia64 ia64 GNU/Linux" since I do not have the adminstratior access.
>> Here is the last portion of message after I executed " ./configure --prefix=/home/you/mpich2-install 2>&1 | tee c.txt"
>> checking for OpenPA atomic primitive availability... no
>> configure: error:
>> The nemesis channel was selected yet no native atomic primitives are
>> available on this platform.  OpenPA can emulate atomic primitives using
>> locks by specifying --with-atomic-primitives=no but performance will be
>> very poor.  This override should only be specified for correctness
>> testing purposes.
>> configure: error: ./configure failed for channels/nemesis
>> configure: error: Configure of src/mpid/ch3 failed!
>> rum06003 at linuxAltix:~/mpich2-1.2.1> make 2>&1 | tee m.txt
>> make: *** No targets specified and no makefile found.  Stop.
>> I wish someone can help me to solve this problem here. Thank you very much.
>> Rui
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
Pavan Balaji
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100524/47a66cba/attachment-0002.txt>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100524/47a66cba/attachment-0003.txt>
Desc: Makefile
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100524/47a66cba/attachment-0001.obj>
