[mpich-discuss] I can not make MPI recognizes a dual core
Yessica Brinkmann
yessica.brinkmann at gmail.com
Fri May 21 13:19:42 CDT 2010
Very thanks for your response.
The problem is that I am using Visual C++ with Visual Studio 2008 and
I am not execute my program from the command line. What I can to do?
Very thanks for your interest.
Yessica Brinkmann
2010/5/21 Gus Correa <gus at ldeo.columbia.edu>:
> Hi
> Even in a single core machine it should work (oversubscribing the
> processor), I suppose.
> Did you ask for two processes/processors in your mpirun/mpiexec command?
> mpiexec -np 2 my_program
> "man mpiexec" is also a helpful source of information.
> I hope it helps
> Gus Correa
> Yessica Brinkmann wrote:
>> Hello. I am using MPICH2. I am writing my first program in MPI. I
>> write the sentences:
>> int id;
>> MPI_Comm_rank (MPI_COMM_WORLD, & id);
>> if (id == 0)
>> / * Master task * /
>> else
>> / * Worker task * /
>> And I write other sentences. The issue is that it does not recognize a
>> DualCore processor, and takes the machine as it only has one
>> processor, indeed, never enters the else.
>> I would appreciate very much any help.
>> Sincerely,
>> Yessica Brinkmann
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
